Question about Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 does not charge or come on
I have a Garmin NUVI 350 GPS which is not powering on when I press the power button. Also when plugged in to the charger in the wall socket, it does not seem to charge. The welcome window that used to com up when connected to a power source no longer comes up so it seems that it is not charging. Can anyone help with this? Is there any dealer or repair shop I can take this unit to for repair or to be looked at?
Thanks in advance.
  • 3 more comments
  • Anonymous Jan 25, 2009
    exact same problem as mentioned above...does not come on even when plugged into a power source!
  • sholaajayi Mar 25, 2009
    my nuvi 300 will charge with the normal power at home but will not charge in the car. I bought a new cable hoping that the old cable was faulty. The same problem occur. If in use when the battery drains, it will stop working. Is it a bettery problem?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Our website is down due to server upgrades. The problem you are experiencing if from a defective main board, which needs to be replaced. This can be caused by a defective charger or using the wrong type of charger. I can help you with this issue.
    - Jim
    SHARCNET-USA
    sharcnet-usa@sharc.net
  • hmrtrain May 11, 2010
    Tried clicking on link above, http://www.sharc.net/nuvi_dead.htm
    and got an "internal server error".
  • SHARCNET-USA
    Please look at this link and see if this is your problem. Too much info to copy and paste here
    Jim
ginko
  • 19396 Answers
SOURCE: garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Posted on Apr 13, 2009
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
  • 504 Answers
SOURCE: Garmin Nuvi 350 GPS is off
If the GPS is off, you have to go into the settings menu and change it. There should be three settings - Normal, GPS off and WAAS/EGNOS. Choose Normal or WAAS/EGNOS and you should be ok.
Posted on Jan 28, 2008
SOURCE: My Garmin nuvi 350, North America, will not show picture.
don't know I to use the garmin 350
Posted on May 05, 2008
SOURCE: Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Posted on Nov 15, 2008
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
I have a garmin nuvi 350. It suddenly quit. It would not power up. I bought new car charger and wall charger specifically for nuvi 350. Both charger would not power up the gps at all. Is my battery dead or...
I would say this is not a battery problem. A Nuvi will power up even with the internal battery disconnect (done it many times myself ) when connected to an external power source. Please see this link about Dead Nuvi's. Have you tried pressing the reset button behind the antenna?
http://www.sharc.net/gps_dead.htm
- Jim
Jan 18, 2010 | Garmin nuvi 350 GPS Receiver
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
New Nuvi 350-can't turn off or on
Try holding the power button down while it is plugged into a household power USB adapter..I don't think it was properly charged??
Jan 10, 2018 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350 power button doesn't work
buy a tom tom everyone is having trouble with garmin and its not just poert buttons tom tom is much more reliable
Aug 14, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
870 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
