Question about Plumbing
Price pfister kitchen faucet one piece spray nozzle won't swivel
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: Price Pfister kitchen faucet two handle with
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Posted on Apr 04, 2009
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
Kitchen fawcett spray nozzle has low flow, however pressure appears
You need to replace the spray diverter valve. It is located on the main body, below the spout, in the sleeve at the base of the spout. The main pivotint sleeve of the spigot. The valve is usually in the rear.
Dec 16, 2012 | Price Pfister Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Price pfister kitchen faucet spot leaking at joint
They are wrong. There is no O-Ring at the swivel joint and it is NOT serviceable.
May 20, 2012 | Price Pfister Plumbing
Looking for a price pfister marielle faucet installation instrucction. Model number026-4nzz
Call price Pfister at: 1-800-PFaucet
They have excellent customer service and can point you in the right direction.
Sep 30, 2010 | Price Pfister Marielle Kitchen Faucet with...
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
798 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
