Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Bosch hbn 7305 built in oven error code 15
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
grandadfixer
  • 99 Answers
SOURCE: bosch hbn s gb
oven element would need model and ENR No. to supply
Posted on Oct 12, 2008
  • 27 Answers
SOURCE: INSTRUCTION MANUAL
you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
Posted on Mar 09, 2009
SOURCE: My Bosch HBN 5605 .0B oven has a 15-20 degree
I detected a similar problem following the sudden appearance of Err1 in the display. (Oven 4-5 years old, and the grill element failed when it was 3-4 years old). This indicated a temperature sensor problem. My local dealer came with his Thermocouple and confirmed an "under temperature" reading on the standard and baking settings. I agree that the fan setting is probably OK. He replaced the sensor. I monitored the situation for a while and was not happy because an under temperature could be quite dangerous when cooking certain foods, and also causes problems when baking bread.
The location of the oven sensor is also a problem because it is at the top right by the grill which also serves as the top heat source.
I had corresponded with Bosch about this and their response was, frankly, less than satisfactory. In the end I decided to call out their engineer (cost £85-ish) who wired my oven up to his computer. In the end he said that the oven was working as it should be (despite it taking a very long time to actually reach the target temperature of 200C.
In my view of I want 200C, then I should get 200C, not an approximation.
Interestingly the secret info (not in the manual) is that the temperature bar readout does not indicate that it has reached the actual temperature, but may be 90% of the temperature (so if you want 200C you get 180C.
An unsatisfactory solution is to get an oven temperature of the meat probe type and put that in the oven, then you will get a more accurate reading of the temperature. You would need one that goes above 200C (my first one only goes to 200 but I have found another that goes to 250C). Mine is by CDN model DTP482, any good cook shop should stock this.
Andrew Finch
Posted on May 05, 2010
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch oven glass
http://www.bosch-home.co.uk/store/spareparts/search
Feb 20, 2013 | Bosch HBN 9061 / HBN 9021 Double Oven
Instructio manual for a Bosch oven HBN 574850
http://www.bosch-home.co.uk/customer-service/download-product-manuals.html click on link, open new window as indicated and type in the ENr number without spaces, you can then download the manual (IU is user manual, II is installation instructions)All the best
Aug 29, 2011 | Bosch HBN 742 / HBN746 Electric Single...
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
INSTRUCTION MANUAL
Feb 23, 2009 | Bosch HBN 131560B / 131520 hot-air...
Bosch hbn s gb
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
181 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
