Question about Kenmore KSM100 Stand Mixer
For Model #KSM100 Salton Mixer, I got big noise first, then something broken. I opened, saw one small plastic gear broken. Where can find this part? I check sears website, they don't sell this part.
2 Suggested Answers
  • 10 Answers
SOURCE: I would like to know if the Kenmore 600 KSM100
It does not.
Posted on Dec 08, 2010
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I purchased a used Kenmore Stand Mixer Model KSM100 that makes a loud grinding noise when its running. I need a manual and advise on how to repair it.
I am sorry Roland. I have searched for this manual but it appears to be unavailable.
You can post a request on www.manualsonline.com and someone who has a similar product may upload it for you.
By the way this service on Fixya.com is only for sourcing manuals and not providing service information.
The grinding noise may be due to bearing failure in the motor or gear failure.
Sorry I can't be of more help.
Oct 03, 2011 | Kenmore KSM100 Stand Mixer
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
I am looking for gear and transmission parts for my kenmore ksm 100 stand mixer. Where oh where can i buy parts for it. Thanks much.
go to www.sears.com under parts direct. enter model number and search out needed parts. The model number will have three digits, then a decimal, then the rest onf the number aka. 110.0012300
Jul 07, 2009 | Kenmore KSM100 Stand Mixer
How to buy accessories for the kenmore stand mixer model 23869253
The Kenmore 600 Watt Stand Mixer uses KitchenAid Accessories.
Dec 15, 2008 | Kenmore KSM100 Stand Mixer
Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Nov 26, 2008 | Hobart A200 Stand Mixer
KitchenAid KSM90 gear stripped?
I just ran into this problem when the PLASTIC worm gear broke and then the mixer would not power on after I replaced the gear. The problem was due to the was I tried to dissasemble the mixer. I removed the two plastic screws near the top center of the mixer when attempting to disassemble. These do not have anything to do with the assembly it turns out the attached square pieces (attached to these screws by springs) must be in the proper orientation to run. I put them in the way it showed in a diagram but it did not work until I tried all four different combinations that they could be rotated. Two of the rotations on the square could be eliminated by closely looking at the end where it contacts the shaft. The round shaft marking will be evident on the square inserts. I'mnotsure how to better describe them, but the are attached by springs to the plastic screws on both sides of the top of the mixer.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Kenmore KSM100 Stand Mixer Logo
Top Kenmore Food Mixers Experts
Jim Thurston
john h
NOEL
NOEL
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
