Question about Toshiba 50HP81 50 in. Plasma Television
Toshiba 50 plasma tv
I do not know what happened but after playing my xbox 360 i went to watch tv when i noticed there is a thick 6 in black srip going top till bottom on the middle of the screen what should i do
SOURCE: Red Excited Pixels when screen in is black
power supply is miss fireing.
Posted on Jul 27, 2007
  • 63 Answers
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Posted on Nov 25, 2007
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
  • 2267 Answers
SOURCE: Toshiba 42HP 84 Black verticle line -- 1 inch thick and running from almost center vertically down to middle of screen
Just repaired one of these with the same fault. at the bottom of the plasma panel you will see a row of ribbon connectors, on the back of the ribbon connectors are some surface mount components. resolder these components on the offending connector, clean the contacts on the ribbon connector and reconnect. unfortunately getting to the connectors is quite a job, so give yourself plenty of time. if this doesn't cure the fault then the poor connection is on the plasma panel which you cannot repair, the only option then would be to replace the panel.
Let me know if you require further assistance.
Posted on Apr 14, 2008
  • 1779 Answers
SOURCE: My 50" Plasma has developed a band across the middle of the TV
I would have it looked at before saying it is burn in, a BLACK horizontal line across the set is loss of data to the display from the Y-drive panel. This is something the customer should not attempt anyway, however, if it is either the upper or lower drive board they are not that expensive. Let me know the outcome.
Posted on Feb 04, 2009
  • 34 Answers
SOURCE: xbox 360 toshiba samsung drive problems
Posted on Aug 07, 2009
0 characters
1 Points
Delay o plasma Tv
You have the HDTV switch flicked on or your xbox av cord to the tv? the settings on your xbox console should also be corresponding to you having a HDTV, if it is set for 4:3 or reg NTSC standard it would cause you problems
Apr 14, 2010 | Samsung P50HP 50 in. LCD TV
3 inch thick black line almost at centre of screen
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV.
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 03, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Tv screen keep going black,
did you check the sleep mode on the tv?
Aug 05, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Plasma screen
do you have the swich on the back of the xbox plug set up for reg tv? Does it work in that mode with just the red, yellow and white wire in the side AV slot? If you were using the xbox on another tv its possible you modified the display settings in the menu. Try hooking it up to a standard tv and reset the setting to default then try rehooking it up to the plazma.
May 20, 2009 | LG 42PC1D 42 in. Plasma Television
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
May 06, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
TV went black - Please wait message...
I think you both have faults on the line output stage of your tv either the line output transistor has become faulty or the line output transformer itself has become faulty. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Aug 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Light and dark
hi there, you have a hardware prob. , try the inverter of the lcd, replace it and test it. ty
Feb 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Toshiba 50HP81 50 in. Plasma Television Logo
21 people viewed this question
Top Toshiba Flat Panel Televisions Experts
Jaime Hernandez
Are you a Toshiba Flat Panel Television Expert? Answer questions, earn points and help others
