Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refridgerator Freezer works fine -- Fridge side not cold enough.
  • 237 Answers
That can be due to several problems but usually because the air from the freezer side can't make it over to the fridge side. If the defrost cycle is not working the freezer coils will freeze solid and no air flow over them to make it to the other side. Or the fan that blows the air over the coils is out. Or the damper that lets the air into the other side is not working. Or the t-stat the controls the damper isn't working, etc. Lots of things to look for but here's a few hints.
If the freezer side is cold just on the bottom but not so much on the top suspect the coil froze up (no defrost cycle working). Sometimes you'll see lots of snow type ice on the back lower wall (dead give a way). You can listen to see if you hear the fan running about in the middle of the freezer compartment (the fail quite often). You can try and find the damper "window" (will be high up near the top) between the two compartments and see if it's fully open, also the "return air" (will be low near the bottom) is blocked (loaf of bread, etc.). Lots to look for but concentrate on why the air isn't making it to the other side. Let me know if you need further help with testing depending on what you find.
Posted on Jan 06, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Side by side w/ dipenser ge refridgerator
Your unit is under charge and need to check for leak. Please call qualified technician.
Jan 01, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
