Sanyo portable washer ASW 33NP Spins, but does not drain water
Sanyo asw 70st washing machine makes lot of nose while spinning
Can any one provide me the Instruction manual for Sanyo #ASW-70ST?
Feb 23, 2017 | Washing Machines
My washing machine wont spin
Sounds like the belt broke on your washer.
Easy to replace and not that expensive.
Mar 09, 2015 | Washing Machines
Sanyo asw 33np
Plug off the mains on the wall. Tilt your machine towards the front to examine the bottom. Use something to safe- guard the front. Look to see if any pipe, hose has become loose or disconnected. Tighten up with hose pliers to secure. Usually solves the problem. Please rate if helped.......................thanks.
Jan 13, 2014 | Washing Machines
How to open child lock on sanyo asw-a85ht washing machine
Apr 07, 2012 | Cars & Trucks
My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
I just got a Sanyo portable compact automatic washer ASW 33NP. I tried it out and when it gets to the drain cycle it just buzzes a little but doesn't drain. Is there a way i can try to fix it?And is there...
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Washing Machines
Washing machine does not drain- Sanyo Asw33np
Am not sure of whether washing machines spins or not. But would like to help in either way of the problem
If it doesn't spin or pump water
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If
it spins, but doesn't pump water
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Credit to chad fix it
Jul 29, 2008 | Washing Machines
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
