Question about Konica Minolta - Magicolor 1600 1600w 1650en Drum
Konica minolta 1650EN service call 0500 - Konica Minolta - Magicolor 1600 1600w 1650en Drum
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
checkitright
  • 1362 Answers
SOURCE: Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Posted on Aug 25, 2008
goalie39
  • 469 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
My printer says "Belt Error" how can I fix this?
The printer detected incorrect
image position on the image
transfer belt.
Check the cyan and black
toner cartridges and replace
them if they have run out. Page 171 of Konica Minolta Magicolor 1650en Laser Printer Manual...
Nov 16, 2014 | Konica Minolta A034012 Magicolor 1650en...
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
Konica minolta service call 0092
Check the transfer belt, incorrectly installed? Where directions followed?
May 10, 2012 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Konica Minolta 1650en Service Password
The ICs for this series of machine are chipped, IIRC. The only way to reset them is to install a new unit, or buy a reset chip from ebay.
Feb 27, 2012 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Error k toner life end in konica menolta 1650en
Purchase a new toner or does it say Image Unit life?????
Dec 02, 2011 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Only printing black, no colour. magicolour 1650en
If there are color toner cartridges installed, then make sure that you are using the correct drivers for the printer. If the drivers are not correct, then it will only print in black and white
Mar 04, 2011 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Open Questions:
See all Konica Minolta - Magicolor 1600 1600w 1650en Drum Questions
Konica Minolta - Magicolor 1600 1600w 1650en Drum Logo
191 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
