Kenmore air conditioner model # 580. 75080500 keeps turning on and off but sometimes the lights stay on while its off making it seem or look like it is on. Camt turn.it off completely unless it's unplugged. Anyone know whats wrong with it and how to fix it if possible?
SOURCE: Blinking green light stays on and TV won't turn on.
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
Posted on Dec 14, 2007
  • 1122 Answers
SOURCE: Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Posted on Dec 16, 2008
  • 37 Answers
SOURCE: AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Posted on Jun 12, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
  • 8457 Answers
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Posted on Jan 19, 2010
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Kenmore the biggest 110 unit you can get, keeps shutting off
there is something wrong with your switches maybe. Or the thermostat problem occur.
Jun 01, 2009 | Kenmore 76129 Air Conditioner
Safety plug on unit keeps popping out after running a while.
You have a short somewhere. With any luck you might have a wire come loose from the compressor.Side the unit out and remove the cover. Inspect the terminals on the compressor. if they are all fine then check the run capacitor. If it is swollen or leaky then it has failed. If that is fine then i would next check for continuity between each pin to ground on that conpressor. if you have any continuity on that then it is compressor replacement time.
Apr 09, 2009 | Kenmore 75101 Wall/Window Air Conditioner
Power cord
The unit may be drawing more current than the outlet can withstand. Also check to see if the chord is secured and properly installed. The outlet itself may have a loose wire so check to make sure it's good. Otherwise it could simply be the reset switch is burnt out and will keep tripping no matter what. Replace if neccessary. Hope this helped.
Jul 20, 2008 | Kenmore 75085 Air Conditioner
Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Aug 07, 2007 | Kenmore 73189 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
