Question about Air Tools & Compressors
Mastercraft coil roofing nailer leaking air at head
Nailer leaks air at hammer head all the time
3 Suggested Answers
  • 7 Answers
SOURCE: constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Posted on Jun 10, 2009
  • 1388 Answers
SOURCE: my nailer leaks air out the back
Hitachi nailers are built on very close tolerences. Dirt /grit will prevent cylinder from resetting causing air to leak out of top of gun. You can force a reset by striking the gun head first against a rubber mat. Only one or two hits because you could damage the head. If the gun does not reset you will have to take apart and clean out grit and replace orings as needed. Good Luck and post again if you have other questions.
Posted on Mar 20, 2010
How to remove a broken nail head from the driver pin
It depends on how it is jammed - most of the time you need a long drive punch the diameter of the driver and carefully hammer the driver past it. The roofing nailers aren't as hard to free as the framing guns so you should not have any trouble.
Jun 04, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Blowing air out of trigger
Leaking under trigger could be the ball seal part # 875645 if leak starts as soon as you connect the air hose. If no air leaks when you connect hose but begins to leak when you depress the trigger then replace the oring on the plunger which is part # 874820. If air leaks when you connect the hose and the ball mentioned above is good then most likely is leaking from oring # 876161 installed on cylinder plate (remove head and pull out the plate). Good luck.
My hitachi roofing gun leaks air from trigger when not pressed
Two areas to check when air leaks from around the trigger. Rubber ball under trigger pin will cause air to leak, however when good side of the ball falls on the seat, air will not leak for a while. If air is leaking from plunger pin (just in fromt of the trigger pin), remove the head and pull out the cylinder plate to reveal broken oring (oring part # 876161). Good luck with your repair project.
Jun 05, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
I have a nv45ab roofing nailgun & it blows air out of exhaust on top any sug.
Hitachi nailers use an unusual design of actually moving the cylinder to fire instead of moving the headvalve. If the cylinder gets stuck in the open position (down), air will leak out of the head. To reset the cylinder, remove the nails and connect air supply. With air connected, lightly rap the head of the nailer against coiled air hose or soft rubber (too hard of a hit could damage the head). If after a couple of hits air still leaks, remove head and check headvalve for cracks. Replace as needed. If headvalve rubber looks ok, remove cylinder and clean/lube. If cylinder has fine scratches where orings make contact, sand smooth with 400 grit sandpaper. Lube with silicone paste, white grease or nailer oil.
Jul 29, 2011 | Hitachi Tools & Hardware - Others
Hitachi roofing nailer leaks air out the back after falling off roof, I have 5 of them all with the same problem. any ideas?
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
Dec 11, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Air leak top of gun senco oil less coil nailer scw40r. unclehhotmail.comowd@
Nailer scn40r is an oil less coil roofing nailer. If it will not fire and leaks out head then most likely problem is diaphragm torn or pinhole. Replace firing valve part # BAO120 for good as new operation.
Order parts from www.toolpartsdirect.com
Oct 16, 2010 | Senco Tools & Hardware - Others
Hi, i got a hitachi nv45ab and My nailer leaks air out the back
Hitachi nv45 series is the most popular line of nailers amoung professional roofers. There are three areas that develop leakes. Leak out head vent indicates cylinder stuck in lower position or headvalve worn. With air connected, gently rap head of gun against rubber mat to move cylinder to position. (Use caution not to damage head). If this action works, gun needs cleaning internally or lack of oil. If air still leaks out vent remove head and examine valve in head and replace as needed. Check that cylinder moves freely up/down (travel aprox 1/4"). If cylinder is hard to move pull cylinder and clean replacing orings as needed. If leaking around trigger, remove rollpin and trigger and check nylon ball for pits and replace as needed. If leaking around base of gun check for loose bolts and/or worn gaskets. Remove nail canaster to check feed piston gasket and screws. Good luck with your repair and post again if you have other question.
Aug 04, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
My nailer leaks air out the back my,roofing nailer wont hold any air
Mar 10, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Constant air leak
Jun 09, 2009 | Stanley Bostitch Coil Framing Nailer
Air Tools & Compressors Logo
55 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
