Question about Sprint Hitachi P300 Cellular Phone
Color bar showing on plasma screen off and on
Possibly coincidental, after installing direct TV my plasma occasionally has a color bar appear from top to bottom like a split screen. Color varies from green to yellow to red. usually appears after set is on for 15 minutes or more but sometimes disapears after 30 minutes only to reapear.If a video or CD is played it does not appear.
  • 3,037 Answers
Hi kumquatgus
Sounds like the signal for the direct TV is causing this. Contact your provider and make them aware of this and have them replace their system with a new one
bestdarngood
Posted on Jan 05, 2009
  • 19,396 Answers
If you do not get the problem when playing CDs , then the problem is associated either with the tuner board, or with the digital processing circuits on main board.
  • Ginko
    Ginko Jan 05, 2009
    If you use an external receiver also check cables to receiver.
    If you use HDMI, try a different HDMI port , and if you have it a different cable.
    Try also hooking up a different receiver, it may also be a defective receiver.
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
New Samsung Plasma HDTV
That is what is called BURN IN or as the manufactures call it "IMAGE RETENTION". Basicly what this means it that you have been putting more hours on the part that is darker the smaller part, or the 4x3 picture or the square part. And, basicly the part that appears to be lighter is "LESS" worn out than the other part of the plasma tv. There is no fix for the problem, But if you go into the menu and select "BURN-IN" OR "Pattern sweep" or WHITE Screen than you will see exactly what i mean. Now, you can keep it on this pattern overnight if you would like, but i suspect it will not cure the problem, but lessen the effects of it. But keep in mind, you are reducing the life of the complete panel when you do this. Not that it is bad to do this. If you have anymore questions don't hesitate to ask anymore questions. The better fix is to Switch over to the "Dish Network and than you can format the screen on any channel in any mode. Superior product to cable. Have a great day. And watch out for the snow storm coming. GURU JAY
Mar 18, 2008 | Samsung HP-T5064 50 in. Plasma HDTV
Sprint Hitachi P300 Cellular Phone Logo
24 people viewed this question
Top Sprint Cell Phones Experts
Dan Shibata
Dan Shibata
 steve
steve
Brett Duxbury
Brett Duxbury
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
