Question about Prestige APS686T Remote Start and Keyless Entry System with Additi
I have a Prestige APS-55C Remote Car Starter installed in my car and lost the transmitter off my keyring. Where could I replace it?
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
LVT7857
  • 116 Answers
SOURCE: prestige remote starter fell in bowl of water
Wasn't the unit hooked up already? You can't plug it back in? I'm still trying o picture the dropping into a BOWL? of water???
Give me the model and I can give you color codes, but if the wiring is still in tact you shouldn't need to rewire. Let me know and I'll help you out.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
MECP Guy
  • 344 Answers
SOURCE: prestige starter not working in 1996 toyota corolla
sounds like your unit is in valet mode
Posted on Feb 15, 2010
SOURCE: I bought a car with this starter (below)and no one
I'm not sure about trunk but to start the engine press twice green buttun and engine should start and to shutt it off press green button once.
Posted on Jul 22, 2010
Aps51 won't learn tach
Never heard of an APS 51, Prestige Remote Starter.There is a APS 57. If it is a 57 then yes.
Jan 24, 2014 | Prestige Remote Start
I have a prestige aps 901 I just replaced the car batterie now the remote start will start the engine but imediatly shuts off what needs to be reprogramed?
check the fuse and relay to the remote start if not that then it might be the module itself if it is aftermarket it was probable shorted out when battery was changer and may need a new one
Jan 23, 2014 | APS-901 Prestige Remote Start
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
Car starts then stalls I have installed a Pretige remote car starter on My 2005 Cadillac Escalade EXT. I have the bypass installed with the key in it. The truck starts then stalls. Any answers?
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Jan 20, 2011 | APS-901 Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Feb 23, 2009 | Car APS921 Remote Starter - Keyless Entry
Prestige platinum by audiovox need to replace the remote for it
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Prestige aps-57 remote start...car won't start
Thank you,
Luis
Dec 01, 2008 | Prestige Remote Start
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Prestige APS686T Remote Start and Keyless Entry System with Additi Logo
48 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
