Question about AEG Refrigerators
AEG Santo S75438KG lamp replacement
The lamp in my AEG Santo S75438KG need to be replaced and I can't find how to do it.
SOURCE: AEG Santo 2340-8kg
I have the same problem - spent ages trying to find a solution and then eventually stumbled across this:
http://www.howtomendit.com/answers.php?id=16043
Haven't tried it yet but it's worth a shot. . . .
Posted on Jan 03, 2008
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
SOURCE: AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
Posted on Nov 30, 2010
caroldon
  • 17130 Answers
SOURCE: AEG OKO Santo not sure how old There is a hum
The hum on the motor can be faulty compressor motor or a weak capacitor that makes the motor to move slowly.But If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Posted on Sep 03, 2011
  • 195 Answers
SOURCE: finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Posted on Jul 05, 2012
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
Feb 22, 2013 | AEG Santo 7085 KG Side by Side...
Finding a refrigerater seal for an old aeg santo 1605
Jul 04, 2012 | AEG Refrigerators
Aeg santo has stopped working, no power to it
Check the wall outlet for power and your breaker box for a popped breaker. Rate me if I am correct!
Aug 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Feb 20, 2010 | AEG Santo 7085 KG Side by Side...
My aeg santo 70168 has a puddle of water at the bottom every few days.
if the water is inside check the drain on the back of the fridge if it is on the floor make sure the drain hose is in the drsin pan
Dec 07, 2009 | AEG Santo U 86000i Compact Refrigerator
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Oct 06, 2008 | AEG Refrigerators
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
Feb 24, 2008 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
ashburton
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
