Cant remove stand from atec tv
Cant remove the base stand
SOURCE: stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Posted on Nov 19, 2008
  • 326 Answers
SOURCE: need to remove base from Proscan 32" TV
The stand can be removed by unscrewing six phillips-head screws from the back panel. A plastic insert plate is provided to cover the bottom hole that is left when removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
Posted on Mar 26, 2009
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
SOURCE: atec 37" tv remote code
the tv is set up but the remote is not moving the tv to a next channel. it is moving the volume. Model LC26HA27 Etec TV ( Flat screen)
Posted on Nov 17, 2009
  • 1039 Answers
SOURCE: TV stand stuck to dresser
Try spraying a little water near the feet and apply heat from a blow dryer. Not too much don't want to melt anything.
Posted on Nov 24, 2009
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
Im having trouble removing the base stand, I'm trying to mount it on the wall. I removed the 4 screws on the bottom but cant get the metal legs off.
Generally the stand is screwed on from the back of the TV. there should be 4 screws that will come out all the way and allow for the stand to be removed
Mar 13, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Tv stuck on stand by.thought remote was playing up .how can i get it to switch on
Reboot. Turn everything off. Important: unplug from electrical outlet. Power is still feeding into appliances when they are turned off. Wait 10-20 seconds. Plug everything back up and restart.
Mar 13, 2010 | Atec Dusty Baker on Hitting Interactive...
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Removing swival base
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Andy
Jun 25, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
