Question about Philips VR750 VHS VCR
Has philips VR765 composite video out on scart connector?
I want to record my tapes on a iMac with Elegato iTV Hybrd with L,R, composite video connections. I need to know if the VR765 has composite video output on the scart connector?
  • tim_geraedts Jan 05, 2009
    Thanks for you swift response.
    I need to be sure, before I buy this connector if the VCR has a composite video output signal on pin 19 of the scart connector. Do you know?
  • tim_geraedts Jan 06, 2009
    Thanks a lot for your information!! I bought the connector and it works perfect.
  • 905 Answers
You will need to get this to make the scart a composite connection http://www.svideo.com/scart.html
Posted on Jan 05, 2009
  • jason Jan 05, 2009
    Pin Name Description Signal Level Impedance
    1 AOR Audio Out Right 0.5 V rms <1k ohm
    2 AIR Audio In Right 0.5 V rms >10k ohm
    3 AOL Audio Out Left + Mono 0.5 V rms <1k ohm
    4 AGND Audio Ground
    5 B GND RGB Blue Ground
    6 AIL Audio In Left + Mono 0.5 V rms >10k ohm
    7 B RGB Blue In 0.7 V 75 ohm
    8 SWTCH Audio/RGB switch / 16:9, slow switch (10-12v), to force tv to switch on a mode (depends of the tv(old), sometimes set tv to AUX)
    9 G GND RGB Green Ground
    10 CLKOUT Data 2: Clockpulse Out, used in the 80"s by old videotapes
    11 G RGB Green In 0.7 V 75 ohm
    12 DATA Data 1: Data Out (Unavailable ??)
    13 R GND RGB Red Ground
    14 DATAGND Data Ground, remote control, wired and used by old videotape recorders
    15 R RGB Red In / Chrominance 0.7 V (Chrom.: 0.3 V burst) 75 ohm
    16 BLNK Blanking Signal, fast switch (1-3v), to force tv to switch on a mode (depends of the tv(recent), sometimes set tv to AUX) 1-3 V=RGB, 0-0.4 V=Composite 75 ohm
    17 VGND Composite Video Ground
    18 BLNKGND Blanking Signal Ground - ground for slow or fast switch (ground for pin 8 or 16)
    19 VOUT Composite Video Out 1 V 75 ohm
    20 VIN Composite Video In / Luminance 1 V 75 ohm
    21 SHIELD Ground/Shield (Chassis)
    hope this is a fixya!
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
What does scart mean?
images?q=tbn:and9gcsq3imtjhqb0abmt8dptscde8waay3n_hlomxu7sbdjgyrsqmaoxypwoa
A SCART connector is a physical and electrical interconnection between two pieces of audio-visual equipment, such as a television set and a video cassette recorder (VCR). Each device has a female 21-pin connector interface. A cable with a male plug at each end is used to connect the devices. (The 21st pin is actually not a pin but a ground shield contact.) Stereo audio, composite video, and control signals are provided in both directions. RGB video signals are input only. The interface is an industry standard
originated by the French company, Peritel. Today, most new television sets and VCRs in the European market and other countries that use the PAL video standard come equipped with a SCART connector. SCART stands for Syndicat francais des Constructeurs d'Appareils Radio et Television. The connector is also known as a Euro-connector.
Although it is possible to build your own connecting cable, knowledgable people recommend buying a commercial cable because of the detailed pin-crossovers and close pin connections. Differerent cables serve different purposes. A cable for connecting a VCR or a TV set to a high-fidelity audio system needs to use only three of the 21 pins.
It is more difficult to use the SCART connector to interconnect a VCR to a computer monitor because of the difficulty of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Feb 16, 2012 | InFocus IN72 Multimedia Projector
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
How to connect to sky
Plug your recorder into the SCART connection labelled VCR and plug that into a SCART connector on your recorder.
To record from the Sky box, change the input channel to the SCART connector that the Sky box is plugged into and record away!
May 02, 2010 | Philips DVDR70 DVD Recorder
Video output from tv to recorder
You can buy Scart connectors that work either solely as an out put, where you can buy some that are solely an input, look for the type of Scrat with a small switch on it, normally means that it is input/output switchable, it may also depend on the tv's scart plug. if the tv says out put or input then you may encounter a problem.
Nov 27, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
When connecting video or set-top box using composite video cable picture is black and white. If I use S-video I get colour. Video only has scart and tv only has composite/component/s video connectors so I...
you really cant convert to component. it defeats the whole purpose of upgrading your tv. with your tv you should be using hdmi to connect all your devices your cable box should deffinatly have one. any time you connect component to something else you will get black and white hdmi is totally digital where as component is still analog pluse you dont need audio cables with hdmi its just one digital cable
Sep 21, 2008 | Televison & Video
Just got a new LG 42 " tv have hooked up video and it will play tapes but not able to record for some reason. Scart to Scart connection from vid to AV 1 on tv.
Scart is not always two-way, if that is the way you have hooked it up. A lot of newer appliances have one-way scart connectors, and the vid/av plugs are also wired in one direction.
Are you trying to record from the bult-in tuner to the video? Then you would also have to wire from the av-out of the TV to the video in on the video/dvd... essentially doubling up on the cables.
Jun 09, 2008 | LG Televison & Video
I have a Philips DVD player/Recorder which is attached to a Samsung Television and cassette recorder I get a very good picture but no sound. The Phillips recorder is a DVDR 3480
IF it is connected via a scart lead, make sure that the connectors at both ends are pushed in securely to the DVD and TV.
Scart connectors have 21 pins, and the audio pins are at the opposite end to the video pins, so if the connector isn't in straight, you either get sound & no picture or vice versa.
If this isn't the case, give more details on the connection.
May 14, 2008 | Televison & Video
Video output from VHS recorder
does your television have multiple scart connectors? Sometimes some models have only 1 connector that will accept RGB signals... Another thing you can check are VCR settings - scart component video output is not "official" and hence you might need to look at some of the setting if you need to enable it. Another possibility is that your scart cable may not have your rgb signals connected (based on wikipedia reference: "not all SCART cables make use of all the pins, often leaving out RGB signals. In many cases there is also no way to see which type of signal that is currently displayed on the TV set."
May 05, 2007 | Zio Corporation CameraMate RealTime...
Philips VR750 VHS VCR Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
