Question about Whirlpool Refrigerators
WHIRLPOOL FRIDGE FREEZER ARC 7453
WHAT IS HE BLUE GEL THING ON THE BACK ON THE INSIDE OF THE FRIDGE
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
  • 5 Answers
SOURCE: DEFROSTING/ WATER RUNNING ONTO FLOOR & INSIDE FRIDGE
Check to see if the run-off tube at the back is plugged.
I dont know how old the fridge is - but if it a couple years old check at the back or the fridge - there should be a tube running down the back of the fridge down into the bottom tray. This tube funnels water from the freezer (condensation, or water from the defrost) down onto the tray holding the compressor where it evaporates with help from the heat off the compressor. Sometimes this tube can get plugged up with some scum or mineral deposits, causing the built up water to drain from inside the fridge.
The tube shouldn't be too hard to remove and clean out with some hot water and pipe cleaners. Had the same issue on on a GE fridge last year.
Hope this helps!
Posted on Dec 30, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Posted on Jan 25, 2009
TheRepairGur
  • 27 Answers
SOURCE: Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Posted on Jan 26, 2009
  • 7 Answers
SOURCE: water is dripping into refrigerator
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
Posted on Mar 20, 2009
The fridge has quit working. Light is on inside the fridge and freezer but control panel on ice and water dispenser housing is out
It's either a bad control board in the back, bad display board or lack of communication between the two. Check all of the electrical connections on the main board and at the hinge area above the door. Then next I'd check the connections at the display board. I'd unplug the refrigerator before you do the checking to prevent any possibility of electric shock to you or arc to the board.
Mar 24, 2016 | Whirlpool GI5FSAXVY Stainless Steel ...
Whirpool side by side freezer working but fridge not
Hi emmaubiera86,
The issue with the freezer working but the fridge is not is usually the result of a defrost problem. The first thing to check in this case is the freezer area. Look at the back panel inside the freezer. If you notice frost covering the back panel, you have defrost problem. One of the things that happens during this defrost problem is Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section. The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the fridge section of your machine.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | Whirlpool Refrigerators
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Feb 26, 2018 | Whirlpool ET1FTTXK Top Freezer...
Whirlpool fridge and freezer 5 years old, won't stay cold enough
Brush are vac coil in back of fridge, take everything out of freezer and clean inside make sure any drain lines in freezer and bottom of fridge are unobstructed, a small piece of wire ran in and out of these tubes will unstop them. This fixed my fridge.
Good luck
Aug 16, 2009 | Whirlpool Refrigerators
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the parts.like the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool door alarm
Is just a little switch on inside of the door hinge covers if you short it out the alarms will never go off again.
Jun 28, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Whirlpool ARC 5070
Temperature control may have failed. Thermostat causes compressor to cycle on and off with temperature in the refrigerator section. If the compressor is not trying to run and is cold to the touch no power is getting to it. compressor is located in back on the bottom.
Additionally the defrost timer may have stopped working while in the defrost position. Locate the timer and rotate the clutch head screw clockwise a small amount and if the compressor starts and runs replace the timer.
Jun 17, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool ARC7470AL FRIDGE FREEZER
ok you need to replace your thermostat its out of calibration or sticking
Feb 11, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
