Question about Creative Technology Gigaworks T3 2 Speakers
Creative t3 gigaworks subwoofer pcb burnt
Anyone has the circuit diagram so i can exchange the resistors transistors diodes etc
2 Suggested Answers
homedesigner
  • 583 Answers
SOURCE: WILL CREATIVE GIGAWORKS T3 WORK ON A LAPTOP
All you should need to do is plug the speakers into the headphone jack on your laptop. This will turn off the internal speaker(s) on the laptop and route the signal to your T3 speakers.
Posted on Dec 06, 2010
Denon AVR2106 One output channel shorted and blown. 2 power transistors shorted, emitter resistors and base resistors blown Have replaced all, including bias transistor I think bias is still wrong (no...
I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
Sep 07, 2011 | Denon Audio Players & Recorders
A transistor or resistor burnt beyond recognition i need a wiring diagram to identify the type
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
Jan 31, 2011 | Car Audio & Video
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
Dec 06, 2010 | Creative Technology Gigaworks T3 2...
I have a Gigaworks 750, the Audio Pod is not working, however, there is power going to the subwoofer though the power light is flickering. Hope you can help me in solving the problem. Thanks
I did fix this problem and the whole bunch of other ones with the s750 system.
"light is flickering" is a very common! It shows that there is a problem with STANDBY power supply:
1) Yellow glue became conductive (needs to be completely removed)
2) Capacitor malfunctioning C61 (68uF 450)
3) mine had TH1 cracked (replaced from PC power supply) and D9 diode.
If this successfully fixed, you will be able to get 2nd stage power supply on (Relay or power on button)
If you will have problems there, there is a whole bunch of test needs to be done (capacitors, IRF740 etc.)
Aug 29, 2010 | Creative Labs Gigaworks S750 Computer...
The C4460 transistor burnt.I replaced it with an NTE2594 but the same problem happens.Can anyone tell me what I must check before fitting another transistor?
I have the same transistor failed, and the capasitor in the snubbing circuit also failed, I also think there was a cold solder joint on a snubbing resistor. Snubbing circuit opens and then the flyback from the transformer blows out the transistor.
deff a snubbing circuit is a combination of resistor capacitor and possibly diode that absorb the high voltage spike when the transistor turns off.
Jun 08, 2010 | Televison & Video
Megaworks THX 550 does not power up
I was able to repair my sytem using the guidelines from pouakai at (http://forums.creative.com/t5/Speaker-Systems/Successful-repair-of-MegaWorks-THX550-power-supply/m-p...
My system also would not turn on. The problem was on the power PCB - the one with the two large heat sinks attached. I found that the piece of PCB track joining the 2M ohm resistor (connected to the LINE-SENSE pin of the TOP243Y switcher) to the positive output of the full-wave bridge rectifier, was broken. This could have been caused by corrosion from the glue (which covered that section of track). I also replaced the 2M (0,5W) ohm resistor, just incase it was also to blame. The 2M ohm resistor is located under one of the two black heatsinks. I used a short piece of wire to replace the PCB track (from the large filter capacitor next to the resistor) to the 2M ohm resistor. Plugged everything back in, and it worked!
The circuit diagram given on page 21 of the TOP234Y's data sheet was very useful, and helped me understand how the circuit functioned.
I hope this is heplful for others who have this "no power" problem!
Aug 22, 2009 | Creative Labs MegaWorks THX 550 Computer...
Lightning Strike, Plz Help!
Hi. The red line on ICS is quite normal it does not mean the part has failed. To be honest in most cases if a tv has been hit by strike it is a right off & scapped. What I suggest is to remove the main pcb & power supply pcb if its seperate & inspect the print side of pcb for signs of arcing tracking or burnt track. Repair any damaged track by cleaning off the coating to get at clean copper then solder wire accros to bridge the damage. Check the power supply resistors diodes transistors look carefully for any burnt components or components which are physicaly damaged. Check the line output transistor this will be near the large transformer with a thick red ht lead going up to the crt. Check all the components you can in the line stage look at all the ICS to ensure none of them have holes in them or have blown apart. Hopefully you find some or one if your very lucky that is damaged replace it & try your tv.
Sep 23, 2007 | Toshiba CZ36V61 TV
Creative Technology Gigaworks T3 2 Speakers Logo
67 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Jim Y
Jim Y
aliasger yq
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
