Question about Canon SPEEDLITE 580EX TTL Flash
I have a Cannon EOS 40D with a speedlite 430ex attached. The the mode of the flash is stuck in TTl. I want to be in ETTL. When I press the mode button on the flash it only toggles between TTL and M not ETTL.
  • Anonymous Apr 29, 2009
    i have the same problem but with Canon SPEEDLITE 580EX TTL Flash
I posted this over at POTN:
Bringing up a minor-aged thread; but I wanted to add some information that may help others. Here's the best I can remember of what happened earlier...
Tonight, I had one of my three 580II's sticking in TTL. I grabbed another 580II and got the same issue. Then, I grabbed another 5DII, mounted one of those flashes and everything was fine. So far, it seemed to be a camera issue. Out of curiosity, I took the flash that was working and put it back on the first 5DII. Again, the TTL sticks and I think it's more mount related than camera.
I was baffled and a little pissed, but in a hurry; so I didn't think on the spot to take a moment to go into the camera's menu and check settings. I can say that I did check all CFn's, the exposure comp and both flashes on both cameras and everything was fine according to the LCD panels (not screen) on all. I also hand checked all the settings on the flash(es).
Here's how to fix it... it's generally NOT a connection issue from what I have concluded. If you have a 580II sticking in TTL...
I can confirm that the ONLY thing that fixed the issue was to check the settings THROUGH the camera's menu. By doing so, I found the flash exposure comp was dialed down 2 stops on the flash in question - BUT it DEFINITELY was NOT showing this on any screen - either camera or either flash. Everything was set right on the LCD panels. (not screens - I generally only use those for chimping. :D) The result was images were near completely white. Shooting in any mode would not fix the issue. You could not compensate. Even adjusting the EC at cam had no effect - even in M. So, check your FEC THROUGH the camera's back screen. This is (and only) where you will see the issue if it's not a connection problem.
I do believe there's some kind of internal (software?) issue with the 580II's and that's how I remedied it. However, it did only happen on one camera. And while it only happened on that one camera, I can say that as soon as I changed the EC through the screen, it was fine - without touching the connection. I did not experience any loose connection; that's for sure.
From a little research, I found this is a fairly common problem with the 580II's and resides in nearly 100% of the time with the flash as it happens on multiple camera models. However, it's easily remedied if you do the above in bold. ;)
Just FYI and hope it helps.
edit: Just wanted to add that these flashes have never seen moisture and even the camera menu showed "ETTL" when it was in fact not showing that on the flashes screen. Anyway, look at the FEC in the menu. ;)
Posted on May 20, 2009
How to restore factory settings for canon 430exii
The manuals for the 580EX and the 430EX say the following under "Reverting to nnnEX Default Settings": "When nnnEX is attached to an EOS camera equipped with a button, you can press it to revert the xxxEX's settings (except custom settings) to the default.
May 05, 2014 | Canon SPEEDLITE 580EX TTL Flash
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Canon 5D and canon 40D are they type A or type B cameras as per 380 EX manual
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
atdlee@netzero.com
Jan 13, 2010 | Canon EOS 40D Digital Camera
430EX
your flash has a diffusion panel in front, make sure its in all the way
good day
yitzy
Oct 19, 2008 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Canon speedlite 430EX
Make sure it is not set to manual 'M' on the display. To get it to shoot in ETTL (Through the lens) press the mode button and it should read ETTL in the top left corner. This then means that the light is metered thorugh the lens and you are not relying on the manual settings.
Hope that helps. I had the same problem when i first got my.
By the way a brilliant all round bit of kit. I have traveled the world to some fairly extreme temps and got it wet (Rain, humidity, sea spray to deserts and serious dust) All good.
Good luck
Apr 14, 2008 | Canon Speedlite 430EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
207 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
