Question about Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black
My XM radio is not functioning properly please help.
The headphones I got with this unit on side goes on and off in one of the ear buds. Get a good signal but in and out in one ear. I bought a set of sony high performance ear buds but the sound is low even when volume is maxed. Can I send this unit somewhere to be looked at?
  • 43 Answers
Hello Take it to bestbuy and they should be able to tell you whats wrong with it.
Posted on Jan 10, 2009
I have a warranty for my ear buds but Radio Shack has closed. They told me to send broken headphones to you
We are not a repair service center. Fixya can only answer questions. Please do not send them to us.
Sep 11, 2015 | Radio Shack Audio Players & Recorders
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Hello my 50/50 headphones right ear doesn't work, but when i try to move the wire just behind the white plastic of the 3.5 jack, the sound come on and off please help me if there's anything to do to fix...
The wire is broken. Unless you are good at splicing small broken wires, you are better off replacing them. The wires are fragile and can easily break if repeatedly strained. My son goes through ear-buds at the rate of one a month, Sorry for the bad news.
Jan 18, 2011 | Skull Candy 50/50 Headphones
Left earbud completely silent.
Hi,what makes the left hear completely silent it because the wire inside the left side ear bud might have cut and it's not contacting with the speaker inside the ear bud.
What you will do is this, open the left ear bud that is not working, check if the connection is not properly fix. Also after checking if the wires are intact, if the wires inside are intact with no trace of cut inside,that means that the speaker inside is damaged and will need to be replaced..
If you can't do it your self, I would advice you contact a skilled personnel for help.
Thanks for using fixya....
Oct 21, 2010 | Shure (E2G) Consumer Headphones
Left ear bud does not work
yes a coil can burn out in secounds i think you have better have the unit looked at by an technition
Apr 21, 2010 | Sony Bud Style Headphones
I have broke my headphone? now what can i do
depends on where it is broken and whether or not they are ear buds. ove ear headphones or even the on ear, can be easily repaired by soldering the leads back onto the respective speaker. however ear buds tend to be a bit tougher for a novice to solder. if you broke the cable off of the connector, you are better off buying a new pair of headphones modern wires used in the cables for headphones is coated with a colored (or clear, for the grounds) lacquer that is hard to clean off and still get a good connection. good luck, and i hope this helps.
Apr 13, 2010 | Philips GoGear Flash MP3 Player
I can only hear in one side of the headphones
Make sure the plug is fully seated in the playback device. Try plugging the headphones in a friend's .mp3 player. If the problem persists, your headphones are probably bad and will need to be replaced.
Aug 13, 2009 | JVC Gumy Ear Bud Headphone - Peppermint...
Pioneer inno2 Portable XM Satellite Radio Receiver with Home Kit - Black Logo
129 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
