Question about Welding Tools
Plasma cutter capacitor - Welding Tools
2 Suggested Answers
  • 108 Answers
SOURCE: need 2 capacitors for my plasma cutter 1500uf 240v
Hi, can you send me pictures of the caps, all sides. And also next to a tape measure if possible.
Regards
Posted on Jun 02, 2012
I purchased a I60 Plasma cutter and I don't have an instructions manual. Can I download one?
Plasma Cutting Guide - Plasma Cutter Tips - The Eastwood ...
www.eastwood.com/plasma-cutting-guide-plasma-cutter-tips-plasma-cutt...
Check out Plasma Cutting Guide at Eastwood tech library to know about ... hasapproximately 25 amps of output, a 1/2" machine has a 50-60-amp output, while ...When buying a plasma cutter, the manufacturer should provide cutting .... Finally, follow all safety tips and guidelines that are detailed in your instruction manual.
How To Select And Operate A Hand-Held Plasma Cutter ...
https://www.millerwelds.com/.../how-to-select-and-operate-a-hand-held-...
The actual process of operating a hand-held air plasma cutter unit is relatively .... If you only have 115V primary service, don't worry. ... 50 or 60 Hz. This means you can plug this plasma cutter in anywhere in the world. ... If you opt to purchase such a unit, position it as far away from the particle ... Plasma Cutting Roller Guide.
Best Plasma Cutter Reviews 2015 - AIR TOOL GUY
Dec 27, 2015 | Welding Tools
I have a simadre cut50D an I don't have the ground cable can I still use it?
No. Check here for the specifics of how plasma cutters work: http://home.howstuffworks.com/plasma-cutter4.htm Without a ground cable, you cannot complete a circuit, and the physical basis of how a plasma cutter works doesn't function.
Sep 13, 2014 | Welding Tools
Change cebora prof 55 plasma cutter from 3ph 4oov to 1ph 230v
Sorry but you can't change a prof 55 3ph to monophase. The 3ph transformer is simetric, but the 1ph prof 55 transformer isn't.
You should change transformer and add a bank of capacitors to compensate the lack of power.
Dec 14, 2013 | Welding Tools
Need 2 capacitors for my plasma cutter 1500uf 240v
Regards
Jun 02, 2012 | Lincoln Electric Plasma Cutter, Pro - Cut...
Plasma victorfirepower 25 guit burning I checked wires ok no dc power
most of the time when a plasma cutter won't get power the cause is a blown capacitor on one of the boards.
High humidity sometimes causes this problem,be careful when messing or looking at any capacitors because they can hold a charge for days.
Nov 23, 2010 | Welding Tools
How hard is it to change out the main circuit board on a spectrum 375 plasma cutter? What is the cost of the board?
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Feb 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
No High frequency on plasma cutter
You are from Austrialia yes? If you'll email me at customerservice@plasmametalcutter.com I am sure we can get you going. I know we have chatted before but let get chatting again and have you up and running.
Jul 04, 2009 | A & A Manufacturing Ramsond 40D Plasma...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
