Question about Zanussi Dishwashers
My zanussi zsf6128 dishwasher is blocked I took out the filters and the water is still there how can I unblock the outlet pass the filter ??
The dishwasher won't start the end light just flashes , after I emptied the water out it started but as soon as the water rose above filter it stopped again , I cleaned filters , I think the block is beyond the filter maybe the outlet or hose an I unblock these ????????
  • 833 Answers
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
  • 5 Answers
SOURCE: DI 67 S fault
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
Posted on Jan 15, 2008
  • 108 Answers
SOURCE: Odd fault codes then stops working.
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the filter or pump.
Sure enough there was.
1. Unplug your dishwaser at the wall. Check its off or disconnected.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermittent fault. Hotpoint replaced the unit for a mimum charge. Callout + 40.
Posted on Feb 28, 2008
  • 236 Answers
SOURCE: IDL 700 Dishwasher
it sounds like you are going into flood mode. tip the unit 45 degrees to the side and see if you are getting loads of water pouring out. if so you have a leak and need to check components in the base.
Posted on Sep 12, 2008
SOURCE: check water light is on
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Posted on Jan 17, 2009
The dishwasher isn't completing it's cycle and is full of water
Hi the main reason for this is that the outlet pipe is blocked or the filter at the bottom of the machine is blocked the way to test this is to blow down the water drain pipe to see is its blocked you'll need plenty of puff alternatively the water pump motor is blocked or burnt out it needs unblocking or replaced. I hope that helps you cheers eric
Nov 13, 2017 | Dishwashers
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Zanussi zsf6128 dishwasher water not emptying
Check for a clogged filter, the check the drain pump.
Jan 15, 2014 | Dryers
Indesit D41 Dishwasher draining problem. the filter on my dishwasher isn't letting through water, I attacked it with a plunger but I don't know how to open it up to unblock it. please help
First check this. Clean the water inlet filter at the tap outlet regularly. - Turn off the water tap. - Unscrew the end of the water inlet hose, remove the filter and clean it carefully under running water. - Replace the filter and screw the water hose back into position.
Then, if needed check this. Cleaning the filters
The filter assembly consists of three filters which remove food residues from the washing water and then recirculate the water. They should be cleaned if you wish to achieve the best results in every wash. Clean the filters regularly. The dishwasher should not be used without filters, or if the filter is loose. After several washes, check the filter assembly and if necessary clean it thoroughly under running water, using a non-metallic brush and following the instructions below: 1. Turn the cylindrical filter C in an anti-clockwise direction and pull it out (fig. 1). 2. Remove the cup filter B by exerting a slight pressure on the side flaps (fig. 2). 3. Slide out the stainless steel plate filter A (fig. 3). 4. Inspect the trap and remove any food residue. NEVER REMOVE the wash cycle pump (black detail) (fig. 4).
Always keep the door of the appliance ajar in order to avoid moisture from forming and being trapped inside the machine. Clean the seals around the door and detergent dispensers regularly using a damp sponge. This will avoid food becoming trapped in the seals, which is the main cause behind the formation of unpleasant odours.
Preventing unpleasant odours
Food residue may become encrusted onto the sprayer arms and block the holes used to spray the water. It is therefore recommended that the arms are checked from time to time and cleaned with a small non-metallic brush. The two sprayer arms may both be removed. To remove the upper sprayer arm, rotate the locking ring in an anti-clockwise direction. The upper sprayer arm should be replaced with the holes facing upwards. The lower sprayer arm can be removed by pressing on the side tabs and pulling it upwards.
Cleaning the sprayer arms
After cleaning the filters, replace the filter assembly and fix it in position correctly; this is essential for maintaining the efficient operation of the dishwasher.
Leaving the machine unused for extended periods
If the water hoses are new or have not been used for an extended period of time, let the water run to make sure it is clear and free of impurities before performing the necessary connections. If this precaution is not taken, the water inlet could become blocked and damage the dishwasher.
Cleaning the water inlet filter*
Disconnect the appliance from the electricity supply and shut off the water tap. Leave the door of the appliance ajar.
When you return, run a wash cycle when the dishwasher is empty.
That should cover all your bases
Oct 21, 2013 | Dishwashers
Zanussi zwf1437w
Possibly blocked sump hose( bottom of drum) or pump not running,,,,drain water by putting outlet hose down too ground level, when water drained out put machine on spin. If machine spins ok, then you have a pump problem,,,,if water won't drain out when outlet hose at ground level then you have a blocked hose
May 25, 2013 | Washing Machines
GE GLD6700N dishwasher won't drain
remove the drain hose and make sure its not plugged with food debris then hit the drain/cancel button and put the drain hose end in a bucket and see how much water comes out of the end of the hose if any,if the 2 green lights are flashing this too is a clue to this problem,also make sure you can hear the drain pump running when you start it as explained in the above statement
Oct 16, 2012 | GE GLD6700NBB / GLD6700NWW / GLD6700NCC...
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
Dishwashers Logo
59 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
