Question about Samsung Microwave Ovens
Samsung DE6612S-D 24 Volt Microwave nC Fault
On powering the unit up it runs will not cook then nC fault code apears on display.
MicrowaveSvc
  • 9047 Answers
SOURCE: Displayd LOC Code
The first step is to unplug it from the wall for a few minutes then try again.
In case it helps, model EM-S5595 is unlocked by holding the Stop/Clear button as in the photo below.
If that does not do it, try Sano/Fisher Service at http://sanyoservice.com/ .
You may also have a keypad or control board problem.
Posted on Oct 22, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: my panasonic inverter microwave gets
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Emerson Model MW9325SL microwave oven looses power
It sounds like either a filter is clogged, an air vent in the back is blocked, or the internal cooling fan is not running.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
This overheating can happen if you put it in a cabinet or push it against a wall.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Since it's new, it's under warranty, and any trouble you have should be taken care of.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Posted on Oct 30, 2009
SOURCE: sienens microwave HFT879 fault
Exactly the same problem over here, but after our house was hit by lightning, so not really surprised about the cause of the problem. If you look closely, you can still see the displays on a very low light level. I can still choose a microwave program, turn the time etc, and see the time changing, but start won't just just work.
m.de.man att zonnet.nl
Posted on May 05, 2010
Got nc error code on my roadmate can anyone help and tell me wat this means thanks.
Nc means theres most likely an inverter fault inside the oven. This can be repaired cheap. Contact me for info.
Sep 15, 2013 | Samsung Microwave Ovens
Kenmore microwave 85609 has a 5E code on it
test this steps and fix it. God bless you
  1. Power Issues
    • If your microwave oven won't come on, ensure that the power cord is plugged into an outlet and that the power is on. Replace any blown fuses, and reset a tripped circuit breaker. If the microwave won't run, see that the door is completely closed and that nothing is stuck in it. Ensure that your door is not broken. Replace if necessary. See that you have not started the timer as opposed to the cooking function. Press "Start/Enter" to start your microwave.
    Clock
    • Your display will flash if your power goes out. You must reset the clock. If you do not hear a tone at the end of cooking, ensure that you have enabled the audible tone. Also check that you are using the right command. If your power goes out while your food is cooking, you must reset both the cooking time and clock.
    • Sponsored Links
    Cooking
    • If you see sparks while you are cooking, remove any metal objects or plates with silver or gold trim. If your food is taking too long to cook, ensure that you have selected the correct power level for the food item. Remove any other appliance from the 20-amp circuit line. Additional appliances on the same amp will draw too much power away from the microwave. Also ensure that you have selected the correct food item in the preprogrammed menu. Each microwave has its own error codes. Always read your manual to determine what the error code means. Examples of error codes include "E-11", "E-12" and "E-13." This means that you have a defective sensor, and you must get your microwave serviced. The "SE" error code indicates an issue with your control panel.
    Additional Problems
    • You may hear gear noises, especially a humming noise; the fan will automatically come on while your food is cooking. If your turntable plate makes noise, first clean it, and then see that it is positioned correctly over the roller ring. If your nearby appliances are experiencing electrical interference, move your microwave farther away to correct this problem.
Jul 22, 2013 | Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
Microwave just lost all power in the middle of heating up. no display, no lights, nothing. I have power to the outlet and no breaker tripped
as the unit was running at the time it stopped the fault is simple your microwave has blown its fuse. the question is why? in some cases the fuse simply fails to hold in this case i would replace the fuse and be on my way. or the microwave has suddenly formed a crossed circuit. the fastest and cheapest way to test this is the way most techs do it but its dangerous.!! so you decide weather to do it or have it seen to by a tech. take the back of the unit the master fuse will be at the back just were the power cord runs in replace the white fuse (ceramic) with the same volt and value as the one in it put the back on (for safety) plug it in and try cooking with it if it goes great if not its a big fault and in the bin it goes.
best of luck to you
please take the time to rank my advice thank you.
Dec 02, 2010 | Maytag Appliances Over-the-Range Microwave...
I have a GE SpacesaverXL model JVM1350BW. It does not heat up. The interior light, surface light, fan, clock, keypad all work normally. When a cooking mode is chosen and START is pressed there is a...
I wouldn't worry about the sensor error right away.
Sometimes that's just caused when the door is opened before steam could be detected or steam was not detected in the maximum amount of time.
Once it's all working again, if you still get the error regularly, it may be a bad humidity sensor.
If the internal cooling fan IS running when you try to cook AND the oven is not heating, it's probably a failed secondary interlock relay on the control circuit board.
If the internal cooling fan is NOT running when you try to cook AND it's not heating, the bottom door switch is probably the culprit.
Here's is a file on checking and replacing door switches.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Listen to that very carefully, and listen to yours to see if the cooling fan is working.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let me know if I can help you further.
Aug 22, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
311 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
