Question about Cameras
I need to charge the battery on a Canon PC1354 but I push to button on the bottom right but the compartment won't open
SOURCE: Cannot open the battery compartment to change batteries
I give up...battery compartment so bad I'm returning the camera.
Posted on Jan 28, 2009
  • 214 Answers
SOURCE: My Canon xti stopped working
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Posted on Jun 04, 2011
  • 45 Answers
SOURCE: My kodak easyshare MD41 has
You will just need to buy a new cable.
Something like this:
http://www.amazon.com/Kodak-EasyShare-MD41-USB-Cable/dp/B003HMVF70
Hope this helps! Good luck!
Posted on Jul 27, 2011
t00nz
  • 4738 Answers
SOURCE: Canon powershot SD1300 IS won't turn on, even
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Oct 11, 2011
sharpkins
  • 5 Answers
SOURCE: my canon sd1100 is is
If you get stuck, you can email them at this site: www.camerasandparts.com They just deal with problems on the canon powershot cameras. If you need help, they're excellent for help on these cameras.
Posted on Oct 25, 2011
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
I can't open the compartment to put a tape in or get a tape out. Help
Attach the charged battery first then push the eject button
Mar 15, 2013 | iPhone Apps
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Canon S8100 battery won't charge
well somethings wrong with your canon S8100 battery or you need a new charger, or battery
Apr 24, 2012 | Nikon S8100 Digital Camera
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
What chip do i use
The Canon PC1354 can use MMC, SD, or SDHC cards. MMC and SD cards are limited to 2GB in size, SDHC cards range from 4 to 64GB in size.
Mar 09, 2012 | Canon Cameras
Battery compartment won't open?
Push the cover toward the back of the camera and then toward the end, just as the arrow indicates, then the end of the cover nearest the end of the camera will swing open. Follow the illustration in the "Insert the Batteries" section of the manual (page 12 in my copy).
Feb 19, 2012 | Nikon COOLPIX L18 Digital Camera
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Logitech cordless V220 Battery compartment - can not open.
push on the little button at the bottom of the mouse and slide the top bottom half of the cover toward you. The mouse require 1-AA.
negative of the battery towards the left click button.
Jan 30, 2009 | Logitech Cordless Mouse
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
