Question about Whirlpool LER5636P Electric Dryer
How do you place the belt on to the roller?
Please explain how do you place the belt on to the roller.
  • 135 Answers
The belt loops through the roller and then around the motor pulley - the back (outer) side rides on the idler wheel. Hope this helps!
Posted on Jan 05, 2009
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
I need to replace a cracked deck and worn belt. I need the instructions on how to do these things.
1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
Feb 28, 2011 | Cardiozone Supersport Hr Club Commercial...
Slight thumping noise - bum, bum, bum baa, bum bum bum baa - Dries the clothes fine.
The thumping noise comes from worn drum support rollers. The dryer drum will normally thump slightly as the welded seam of the drum passes over the support rollers. However, as the rollers wear with age, this thumping can become more pronounced. If the model number is correct, the rollers can be purchased as a kit and replaced by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and lift the entire drum with the belt still remove.
The drum support rollers are located along the back wall (bulkhead) of the dryer.
6. Using a screwdriver pry the metal retaining clip off the LEFT roller support bracket. Then, remove the plastic triangular shaped tri-rings off each support shaft.
7. The rollers will slide off the support shaft. Clean any built up lint and debris that may have accumulated around the support shaft and install the new rollers.
8. Install the plastic tri-rings on both shaft, followed by the support bracket and metal retaining clip on the LEFT roller. Use a small nut driver and place it over the support bracket retaining clip and push on to the shaft to get it to seat properly.
9. Apply a small amount of oil on the each roller at the pont where the support shaft inserts through the roller axle. DO NOT get oil on the rubber wheels. This can cause them to slip.
10. Re-install the drum, making sure the rollers are seated properly in the groove around the perimeter in the rear. Make sure the belt is looped around the drum with the groove side facing the drum.
11. Have someone hold the drum in place while you re-install the belt over the tension pulley and motor. If working alone, kneel down so you can see the tensioner and motor and rest the drum front on your shoulder or knee.
With the belt removed, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To re-install the belt the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum.
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement kit is 349241T. The kit includes BOTH rollers, the tri-rings and retaining clip for the support bracket. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 56 and the tensioner is listed as item 53.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Sep 22, 2010 | Estate TEDX640JQ Electric Dryer
Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
May 04, 2009 | Kirby Heritage II Vacuum
HOW TO REPLACE BELT ON kIRBY cLASSIC 111 vACUM cLEANER?
I don't have a diagram, but I might be able to explain it to you.
Take the nozzle off the machine. Remove the brushroller and old belt.
Set the belt pulley to the on postion. Put the belt on the roller and put the roller back into the roller housing with the belt centered. Turn the belt pulley to the off postion. If you look in the hole in the back what you want to happen is the pulley to spin and hook the belt stretching it out.
Put the nozzle back on the machine. Lock it into place and turn the pully to the on postion, and you should be ready to go.
Nov 25, 2008 | Vacuums
Dyson DC07 drive belt replacement
Hi.
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
http://dysonmanuals.llc.nu/
Jun 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I cant get the roller back in place
This guide should help.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Please rate it when you are done reading it if it was helpful. :0)
Marci
Oct 02, 2007 | Oreck XLS700A Upright Vacuum
Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Aug 18, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
