Question about Tripp Lite Smart Pro UPS System
No Power when turn on so battery wont charge
Hi I recently brought A tripp lite smart700ser UPS and i connected the bateries but when i put it to test it comes on and then give me the beeping noise for low battery and when i switch from battery to normal i am not getting any power to charge them can you please help me
  • yenuganti200 Mar 21, 2009
    Hi I recently brought A tripp lite smart300ser UPS and i connected the bateries but when i put it to test it comes on and then give me the beeping noise for ups on and when i switch from battery to normal i am not getting any power to charge them can you please help me
    please some one help me to solve this problem
    my mail id is yenuganti2002@yahoo.com
  • 541 Answers
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
Posted on Jan 05, 2009
My tripp lite smart1000 lcd don't want to charge
Wait for the power to come back on. If it's already back on, unplug the unit from the wall, unplug all devices from the unit. Plug the unit in, turn it on, let it sit for an hour before reconnecting devices to it.
Oct 19, 2014 | Tripp Lite Computers & Internet
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Aug 16, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
Tripp lite problems
Look for a little breaker button on the side of the unit. If there is one, press it in and the unit should recover.
Jul 26, 2014 | Tripp Lite Smart Pro SMART700SER...
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
Tripp Lite OMNI 1000 LCD will not stay on
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
UPS won't charge replacement battery. When power
change the chord wich is connected to u r ups..........
Sep 28, 2009 | IBM Tripp Lite OfficePro 500 (10K1911) UPS...
No Power to outlets, Power light flashes green
Let it charge without anything plugged in to the outlets for at least 8 hours. Then, test the battery voltage again. If you still get less than 11.5 volts on either of the batteries, it's time for a new set. It's recommended that you replace both as the other one, even with a reading of 12 volts, is going to fail very soon. The UPS is trying to charge the batteries to get both batteries, as a pair, to 24 volts. It will continously charge them until it gets there (which won't happen if it's a bad battery) and you'll burn out the new one you just replaced. You can new batteries at www.batteryinternational.com for a fraction of the cost of a new UPS. Hope this helps.
Jun 10, 2009 | Tripp Lite Lite OmniSmart 725...
TRIPP LITE UPS MODEL:5000HW WILL NOT START
Hi Godfrey,
Its very difficult to get a circuit diagram indeed. Did an extensive searching . Not sure if this would help you . Please click on the link bellow.
http://images.google.com/images?gbv=2&hl=en&sa=1&q=tripp+lite+circuit+diagram+for+UPS&aq=f&oq=
Now once the page opens you would find a number of circuit diagram. You can click on the required image to enlarge it.
Thanks
Apr 30, 2009 | Tripp Lite Lite SmartPro DataCenter 5000HW...
Tripp Lite Smart Pro UPS System Logo
482 people viewed this question
Top Tripp Lite Computers & Internet Experts
Joseph Hoffmann
Brian Sullivan
Brian Sullivan
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
