I need the motherboard layout for the IBM U1J3 motherboard
I actually just need to identify the pins on the motherboard for the front USB and the front sound. Which wires go where. Please
  • 119 Answers
SOURCE: front panel pin layout. I need the front panel pin layout especially for the HD IDE active LED.
Howzit
Trial n Error is your best bet on the control pins panel there are two rows, with the power plugged in,with a screwdriver touch adjacent two pins together at a time starting with the top row then the bottom row, when you touch the right two pins your motherboard will power-up, then place the power-switch plug onto those two pins (the writing on the plug facing innwards toward the mainboard) the two pins for the reset switch and 99.9% of the time located directly next to the power switch or directly above the the power pins on the other row. For the LED lights you will have to just try the different pins and the Power LED will remain on as long as your mboard is on, but to find the LED pins for the Harddrive you will have to plug in your HDD and then when it powers up try the pins and the led for the HDD will flicker on-off, that would be the correct one. Dont worry your mboard will not be damaged by this in any way. Goodluck and let me know how you go. Thanks
Regards
Posted on Jan 31, 2008
map9966
  • 2351 Answers
SOURCE: Pin layout for the Front Audio Connector
Hi HomeCPU, if you do not have a manual for the P4M9007MB-8RS2H motherboard than lick the link below & dowload it.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000243
Goto Pg.4- Front Audio Connector Board layout.
Than to Pg.13, Audio Connector: F_AUDIO detailed pic of pin loacations.
please vote...
Posted on Feb 22, 2008
map9966
  • 2351 Answers
SOURCE: No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Posted on Mar 14, 2008
SYSTEM ONE
  • 85 Answers
SOURCE: i am trying to hook up front panel usb ports.
check out this diagram i think it might help you
http://attachments.techguy.org/attachments/107266d1180693321/standard-usb-pinout2.gif
or if the link is unavailable then here is the same info
pins 1,3,5,and 7 are one usb connection
pin 1 = +5V
pin 3 = D-
pin 5 = D+
pin 7 = GND
pins 2,4,6,and 8 are another usb connection
pin 2 = +5V
pin 4 = D-
pin 6 = D+
pin 8 = GND
pin 10 is not used
Posted on Dec 04, 2008
map9966
  • 2351 Answers
SOURCE: pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
http://global.msi.com.tw/index.php?func=searchresult&keywords=K7T+Pro&table=download
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Mike
Posted on Jan 19, 2009
Motherboards diagram
you need to get a new board
Jan 20, 2014 | Computers & Internet
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3440614&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3440614
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
Regards,
joecoolvette
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
Ibm 02r4084 motherboard front audio panel layout
Hello visit the lenovo support site:
http://support.lenovo.com/en_US/downloads/default.page?selector=expand
Please select model and id number.
Lenovo has the support for ibm products.
The ibm site is just for servers.
Select model number in search for drivers or manual.
Or install this software:
System Update helps you reduce the time, effort, and expense required to support and maintain the latest drivers, BIOS, and other applications for Think or Lenovo systems. It enables you to get the latest updates from the Lenovo support site.
http://support.lenovo.com/en_US/research/hints-or-tips/detail.page?LegacyDocID=TVSU-UPDATE
Please download and install the one for your operating
system xp or 7.
Good luck
Nov 29, 2012 | IBM (03R0329) Motherboard
I have the same problem!!!
Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
Aug 14, 2009 | IBM (49P1599) Motherboard
Describ connect front usb in msi motherboard
Diagonally opposite to where you connect you keyboard and mouse, there are pins to connect the front panel USB. You can identify it on the motherboard by the names USB5 or USB4 written on the motherboard. Just connect the front panel USB connector to either of these pins.
Jun 07, 2009 | Intel Motherboard
Lenovo J115 with new Gigabye motherboard - case fan set up
Lenovo's web-site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
should have the information.
What connectors are leading from the front-panel?
One "clump" of wires and one connector, or several separate connectors?
May 27, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
Front panel connection
Hi mubarakdream, please open your manual to page 1-6, motherboard layout. Find USB20_5 & USB20_6 page 1-14, at the bottom of the motherboard. You can plug your front USB onto these USB pins. (Careful, front & side case USB's break very easily). It only takes a slight bump to break.
Leave the motherboard jumper set to default for USBPWR_56, page 1-10.
If you need the Asus manual you can download it from this link;
http://support.asus.com/download/download.aspx?modelname=P4BGL-MX&SLanguage=en-us
If you need more information just post back into here.
Good luck mubarakdream!
Mike
Aug 26, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
