Question about Samsung Refrigerators
My samsung rs21dgrs beeps with power freeze alarm. What is possible solution?
Initially the problem started with water filter indicator going red and now this turned into Power freeze alarm.
  • 111 Answers
SOURCE: Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Posted on Dec 19, 2008
SOURCE: Water Filter Indicator Light on Maytag side by side
Hold light and lock until change filter light blinks
Posted on Feb 11, 2009
  • 3600 Answers
SOURCE: Water Filter Alarm Light
TRY to unplug for 5 minutes and replug it back in that should clear the code and if it does not repost a comment it here to fix it. Hopes this
fix the problem. Avid101
Posted on Jul 09, 2009
SOURCE: my samsung rs21dgrs is making very loud noise
Sounds like your Samsung RS21 has devoloped a known fault.
Your frdige will be cold in the drawers but not cold above this? Also there is ice around the pipe behind the drawers. it is the ice hitting the fan that is the noise and eventually stops the fan which pushes the cold air around the frdige.Samsung have extended their warranty to 5 years to cover for this.
You need to call the Samsung customer care team 0845 7267864 and should be repaired free of charge. - mine was. When you call, you need the full model number and serial number. my serial number was on the outside left hand side of the fridge. The engineer comes out within a day or 2.
Posted on Sep 04, 2009
rickead1
  • 1998 Answers
SOURCE: Fridge beeps every 10 min
what is the make and model number of your machine?on a kenmore the beeping would mean that a door is open on a frigidaire Check what setting the fridge and freezer are set at, could be they are set too high and the freezer fan is icing over.Unplug your refrigerator from the ac outlet, and open the door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door this sometimes works to stop the problem please message me back with any further questions and with your model number and make as well i can only speculate until i know the exact brand thanks again Rick
Posted on Dec 30, 2010
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 14, 2017 | Samsung Refrigerators
Samsung refrigerator alarm beeping continuously
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
May 15, 2016 | Samsung Refrigerators
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
My samsung frige, french doors keeo ringing
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 19, 2015 | Samsung Refrigerators
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
The filter light came on and tghe fidge started beeping. we replaced the filter but the fidge continues to beep. This a side by side Samsung --6 months old.
FILTER RESET
When the filter is replaced, reset the indicator by pressing the “POWER FREEZE” and
“ICE TYPE” button for 3 second at the same time.
If this doesn't work I would call 1800Samsung and have them send a technician to your home to help. The refrigerator does come with a one year parts and labor warranty. Hopefully this helps.
Jan 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
My refrigerator is beeping and the door appears to be closed.
That red basket with a drip coming from it indicates your WATER FILTER needs replacement. That could explain your beeping as well. You need to replace the filter and RESET the alarm.
Jun 04, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
123 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
