Question about Sony VAIO VGN-FS742/W Notebook
VAIO Notebook VGN-FS742/W is not booting
I have not used the notebook for around 6 months and then tried yesterday night and it did not boot. Initially Vaio screen Flashed 2-3 times and then went off. Once I was able to go to user LOGIN but then it went off suddenly. Now after that I tried for almost 20-25 times yesterday and today but unable to boot.
I tried with direct AC current, removed the battery etc, all sorts of possible combinations of batter and AC powwre, but nothing.
When I switch the notebook on, the power light is ON, Hard disk light is on for around 30-40 sec and then goes off. On the top, Scroll, caps and num lights are continuously on. But no sound, the screen is dead black, planning to contact Sony support in another 8 hrs, please help !!!!
  • saurabh1975 Jan 06, 2009
    The hard disk is fine as today I was able to get the data recovered.I showed it to the Sony support and they are saying that the mother board is faulty and has to be replaced. Not sure that if that is the actual cause, could someone please suggest an alternative as the cost of the replacement is INR 25K.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sorry to let you know sounds like hard drive is shot.........
Posted on Jan 06, 2009
  • Priscilla mcdaniel Jun 15, 2009
    sounds like screen blew out or ecitor or did you try an out side monitor ? then get back ..... lala linda
    ---sounds like you have short somewhere need to check usb hook ups most common spots for shorts
    if so must diable this particular port in os set up or get a of piers and disable it fom outside of computer
    lala linda
Drivers windows 7
go to sony website and download the driver
or use driver pack solution
Sep 03, 2013 | Sony VAIO VGN-FS742/W Notebook
My vgn-fs742/w laptop is not powering up
Can you charge it ?
If Yes, you might have run out your battery, please charge it for at least 5 minutes, then try again to powering up.
If not, have you try to pull out your laptop battery and then plug the charger to your laptop then hit the power button ? is that laptop can boot up ?
if Yes, you might need to replace your battery
If Not, you can bring that laptop to service center :D
In some case, if after pull out baterry and laptop can boot up using power adapter direclty, you can put it back the battery to the laptop and the laptop will turn on normaly
Nov 15, 2012 | Sony VAIO VGN-FS810/W Notebook
Need hard drive for Sony Vaio VGN-FS742/W
If it's an IDE? Newegg has a 320GB. SATA can go much bigger, but Sony linked your model to a IDE hard drive.
http://www.docs.sony.com/release/994630300_Rev_D_NO_PHONE.pdf
Oct 13, 2012 | Sony VAIO VGN-FS742/W Notebook
I want to disable sata mode on my sony vaio vgn-fs742/w, please help because i cant reinstall xp on the system and the lan and wireless in not working when i install windows 7 on it.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 29, 2011 | Sony VAIO VGN-FS742/W Notebook
I would try to log onto my laptop, but right after my desktop would flash, it would immediately log off. Why?
because ur laptop have virus log on, now u go to safe mode and use software virus to scan. if u have another laptop u copy file userinit.exe from it and boot from cd after copy this file to c:\windows\system32\
Jan 16, 2010 | Sony VAIO VGN-FS742/W Notebook
I have a Sony vaio vgn fs 742/w notebook which has startup problem.When switched ON -Vaio &subsiquently Window XP appears
I did not understand real problem Please make more specific for the problem. what happens Win XP appears? then stays rigth there? Does not boot? Thank you
JMC
Aug 04, 2009 | Sony VAIO VGN-FS742/W Notebook
VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Apr 12, 2009 | Sony VAIO VGN-FS742/W Notebook
Boot failure
Take out your memory and reinsert it, sounds like your memory got knocked around
Feb 09, 2009 | Sony VAIO VGN-FS742/W Notebook
Sony VAIO VGN-FS742/W Notebook Logo
258 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
