Question about Xerox Tektronix Phaser 850N Laser Printer
Phaser 850N prints commands, not proper file
I have a Phaser 850N and 850DP. My DP started having all kinds of problems, so I made the N my primary printer. Since I was only going to use the 1 printer, I took the memory from the DP and put it into the N, bringing total memory to 256. For the first few days, every time I printed it would kick up a filed to print box, but after a couple of minutes, would print the file. Now, it still kicks the fail to print box, takes almost 3 minutes and then prints a partial file (as in, part of the page will print and leave blank info throughout), then a second page of nonsense command codes. I've put both memory bars in together before, not sure why it's doing this now. Any clues?
    Scholar:
  • 141 Answers
Could be defective memory module. Try taking the RAM back out. You can get replacement RAM from Crucial. You can make your N into a DP by switching the NVRAM chip (or the complete main board).
Posted on Aug 05, 2009
Xerox Phaser7300dt. After paper jam, the printer keeps printing the same page
That's normal for any printer. It's trying to pick up the printing of the entire document.
If it didn't print the same page again after you clear the jam, you would be missing a page.
Apr 13, 2011 | Xerox Phaser 850DP Thermal Printer
Printing PDF on 8400 - example 265K PDF created from Acrobat 9 spools over USB over 22Meg and never prints. Any other files, Doc, XLS, we've tested print fine and fast.
I've ran across this a few times and the only thing that ever seemed to help was turning of print spooling so it would print direct to the printer. It ties up the computer while it prints but it does work. Usually in other programs when you see this kind of error the proper printer hasn't been selected or the paper size is wrong or the file being printed is corupt.
Mar 23, 2010 | Xerox Phaser 8400 Laser Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
There are 2 150 watt halogen lamps in the machine that heat the drum. One or both have burnt out.
May 01, 2009 | Xerox Tektronix Phaser 850N Laser Printer
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Mar 31, 2009 | Xerox Phaser 850DP Thermal Printer
Xerox 8560 37X Fault code
either the paper pulling gears are not spinning properly or they are craked or getting blocked by any dust particles.
or the fuser unit in the copier is not getting properly heated up.fuser unit has to be checked first before replacing and the printer /copier needs to be opened to check the fuser unit.
Feb 26, 2009 | Xerox Phaser 850DP Thermal Printer
Xerox 8200 phaser dp
The drum heaters are out. They are 2, 150 watt halogen lamps that go bad.
That is exactly your problem. I can tell you how to replace them. Not real difficult, takes an hour to an hour and a half.
Nov 24, 2008 | Xerox Phaser 8200 Laser Printer
My printer phaser 7400 can not start no signal no thing
Make sure the printer is plugged directly into a wall outlet, not a surge protector or multi-outlet strip. These devices will limit the amount of power to the machine, causing it to not initialize properly.
Apr 02, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Tektronix Phaser 850N Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
