Thorens TD160 right channel cuts out
I have a Thorens TD160 turntable. I have connected it both to the phono input of my amplifier, and to a separate phono-preamplifier. The right channel (of the turntable) will occasionally become very silent, almost mute. This can almost always be solved by unplugging then replugging the right channel cable. Sometimes playing with the tonearm also helps, or it can introduce the problem. I have measured some resistances. At the time of the problem, I could not get a measurable reading for the right channel, but the left channel was at about 500 ohms. The resistances between the cartridge and the output were about 2-5 ohms for all three cables (left active, left ground, right ground) but for the right active cable, it was over 30 ohms. Am I right to suspect a faulty wire, and how can I fix this?
  • Audio Player... Master
  • 5,487 Answers
Disconnect the wires from the cartridge. Then with the amp on touch each of the four wires with your finger. You should hear a loud buzz on two of the wires one on each channel. If you don't then the connections could be faulty. If you can hear the buzz, get someone else to move the wires connecting the deck to the unit. If you loose the buzz then something is poorly connected.
If all is good and the buzz is present no matter what you do, then either you have a bad connection to the cartridge or the cartridge is faulty.
Posted on Mar 20, 2017
  • 42 Answers
SOURCE: Single sided sound from my RCA/Phono leads
Your query not complete. Please resubmit.
Posted on Jan 25, 2009
  • 104 Answers
SOURCE: Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Posted on Feb 11, 2009
SOURCE: Dual 1009. No audio from the stylus & humming.
I can help with this issue. To keep the platter spinning in manual mode, you have to cue the tonearm up and move it so it is over the record. Then flip the lever to manual. It should stay on in this position. This is a feature and not a bug.
Regarding the audio / humming problem. The Duals had what was known as a muting circuit that engages as the turntable is cycling between rest and play. The fact that you are getting no sound may be an indication that the muting circuit is still engaged. Here are a few things you can try:
1. If the unit was recently shipped, you may need to reset the mechanical function of the turntable. You can do this by locking down the tonearm to the tonearm rest, turning on the power and then flipping the lever for a full automatic cycle. The tonearm will stay fixed to the rest, but the remainder of the mechanical system underneath will be reset to proper positioning (this is detailed in the Dual manual). Of course, this assumes that everthing was OK prior to shipping.
2. Make sure your cartridge is properly mounted with a good stylus, check your tonearm wires (both in the headshell and underneath the turntable and finally, see if you can get underneath the turntable while you run an automatic cycle to see what is going on.
Lastly, if you can't get it going, Check out Bill at www.fixmydual.com He worked on my 1019 and knows them inside and out.
Good Luck,
Jerry
Posted on Apr 26, 2009
SOURCE: Dead left channel
I have had the same problem on my 1210 MKII. I have taken it apart a number of times to replace the original lights with LED's, and naturally thought I messed something up in the reassembly. I actually found that the problem was in the connection between the tone-arm and the pick-up "housing".(Pardon my bad english) There is a little rubber band in between, and sometimes you have to unscrew the "housing" flip the rubber band, and screw it back on pretty hard. Also try cleaning the four contact pins before screwing it back on. I have heard of quite a few having this problem. A pretty obvious thing to do, but I had not thought of it, and it would have saved my from taking the entire machine apart several times.
Good Luck
Posted on Jun 18, 2009
smarthome2
  • 1114 Answers
SOURCE: Turntable output level too low and plain compared to CD, etc.
Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
Posted on Jul 06, 2009
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
Htr-6230 low volume
If I were to guess from the information you submitted, your Thorens, which needs a specific phono input, is now plugged into a high level input, such as an AUX, DVD, CD etc. These inputs are for a 300 Millivolt input device. Your magnetic cartridge is no where near 300 Millivolts; never measured it, but would have to say a 1/10 of that. If your receiver doesn't not have a label that says "phono", you will need a phono preamp to amplify the output of your Thorens, with the very low input, to an output of 300 Millivolts. These preamps are sold just about everywhere, Best Buy, Radio Shack, etc.
Mar 01, 2014 | Thorens Audio Players & Recorders
Hooked up a sony turntable to a sony 5.1 multi channel but there is no sound
If you have no phono inputs on the back, you will get very little to no sound. Phono inputs have a built in preamp to amplify the signal. The only option is to go to a second hand store or ham festival to see if you can find phono amplifier, runs on a 9volt battery.
Mar 05, 2012 | Sony Audio Players & Recorders
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
NO SOUND WITH EVERYTHING PLUG IN .
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
Low Audio
You need to connect the turntable to a PHONO input on your amplifier. Not all amplifiers have a phono input, if yours doesn't you need to get an RIAA pre-amp to plug your deck into & this connects to your amplifier.
This is because although the audio outputs on the turntable look the same as all the other components, they are very different. The signal has not been amplified up to line-level like tuners, CD players, tape decks, etc. You need to get this thin, weak signal boosted.
Your 3 options are:
* Connect directly to the PHONO input on your amplifier if you have one. If you don't:
* Connect deck to a RIAA amp (also called a phono stage) then connect to any input EXCEPT phono on your amplifier
*Connect the deck to a DJ mixer then hook the mixer up to any input on the amp EXCEPT phono.
Dec 23, 2007 | Technics SL-1200M3D Turntable
129 people viewed this question
 Grubhead
Grubhead
