Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 notebook constantly overheating and shutting off
This problem I suspect is an internal hardware problem, I would like some suggestions on some parts to replace to optimize the cooling system and avoid this abrupt shutting down.
My Acer Aspire 3000 notebook has a tendency to overheat and abruptly shut itself off. I'm pretty sure that it's a safety measure so that the heat doesn't melt the circuitry. But WHY does the laptop get so hot in the first place?? Is the fan not adequate enough to cool the system? Is there not enough vents on the bottom or sides to allow the proper air flow?
This problem didn't always happen either. For the first year I owned it I had no problems at all.
Does anybody know any tricks or mods that would help with this problem, or is it even the overheating issue at all?
  • John Kohler Jan 13, 2009
    My notebook, the Acer Aspire 5315-2153, had the same problem, for which I called Acer Technical support. They issued me an RMA (return material authorization) which is good for 90 days. In the meantime I bought a Belkin single fan laptop cooler, powered by a USB port on the notebook. So far it hasn't overheated. I'll send the unit back in about 3 weeks.
    Novelist:
    Champion:
  • 256 Answers
Auto settings in NVIDIA control panel are those which control the temperature of the system. It will check the fans revolution per minute and temperature. Actually it is always better to keep your system in an air-conditioned room which won't result in overheating. By installing the case fans, it will divert heat out of your computer and increase the air-flow.
Get more information to fix Acer Aspire Overheating problem. Hope this information helps you.
Posted on Aug 02, 2011
    Brigadier General:
  • 5,158 Answers
Purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Posted on Jan 05, 2009
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20...
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Oct 21, 2013 | Acer Aspire One PC Notebook
My acer laptop keeps closing down/ Any ideas or ways to resolve it
Laptops sometimes shut down to protect your hardware. If the fan has stopped working for example it may be overheating. Is the bottom of your laptop hot?
Jul 27, 2011 | Acer Aspire 5742Z-4200 Notebook
My acer aspire 3000 turns off suddenly when am watching videos and also when am installing office.
Turn off( shut down or restart automatically)?
It maybe cause from overheating from your graphic memory device/harddware or problem with your processor.
Are you have using fan or anyelse to cooldown your laptop during you using it?
Try something, using any fan that can cold and maintain temperature for your laptop to avoid it from overheating. Overheating is not good. It will cause your motherboard problem or screen monitor problem.
May 24, 2011 | Acer Aspire 3000 Notebook
Dont have the original hard disk in my aspire 3000, but I want to restore it to factory settings ??
Go to the acer site, they have the software. I assume you had everything on the old hard drive. Load windows onto your new hard drive. It will detect all your hardware. Actually, since you changed hardware, it no longer is an aspire 3000. I changed out all my stuff in my acer aspire to keep it up to date. The only thing left is the box. As you change hardware the motherboard will detect and adapt. You may still see the aspire logo as it is burned into the bios.
Jun 14, 2010 | Acer Aspire 3000 Notebook
Toch pad locks up at startup, but work fine in safe mode on acer Aspire 3000
Try pressing Fn+ F9 to unlock the Touchpad
If that doesn't work try reinstalling touchpad as new hardware.
Start-
Control Panel-
System-
Hardware-
Device Manager-
Mice and other pointing devices
click +
right click and delete touchpad-
Reboot
Oct 06, 2009 | Acer Aspire 3000 Notebook
My Acer Aspire 3000, Keybourd Stopped Working
i had the same problem. the battery does something during startup and the only way i found to fix it was to turn it on without a battery while its plugged into the adapter, or leave it in standby instead of shutting down... i dont know if theres a better way, but thats what i do.
Apr 11, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 3000
Try re-installing your sound card driver.
Go to Start
Control Panel
Select Sounds and Audio devices
Select the Hardware tab
Select DVD
Select troubleshoot and follow the instructions
Dec 19, 2008 | Acer Aspire 3000 Notebook
Acer 3000 - disassembly instructions in order to change out dc computer connection
goto GOOGLE.COM
then write the same thing as below
" hardware structure of acer aspire 3000 laptop"
that's it...
Dec 01, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5000 series laptop
Just check in the power options that anything is not set to shutdown if idle like the hard drive. it sounds really to be processor overheating problem, just check around the side and underside vents for any blockage. Does your fan appear to cut in at any point and stay on or not come on at all, as these things ay be a clue to the problem if it's the processor overheating and shutting down.
Apr 19, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
