Question about ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card
Graphics driver for x1300 pro agp
Will the new 8.12 catalyst driver on this x1300 pro agp card
  • 56 Answers
Yes it will definetly works;-) go pro go ati:D
Posted on Jan 06, 2009
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
Dec 21, 2010 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Problem with drivers sapphire radeon hd 2600 pro
For this card you will utilize the ATI Catalyst Suite:
To obtain this siftware, visit the ATI website by click here http://game.amd.com/us-en/drivers_catalyst.aspx
Select the Full Catalyst Software Suite by clicking on your Operating System.
After you have downloaded the software, foloow the instrctions to install.
Apr 27, 2010 | Sapphire RADEON™ HD 2600 Pro, Graphic Card
Low brightness on second monitor using Radeon X1300 video adapter
According to the X1300 specifications here it does support multiple displays. The option to configure the display is found in the Catalyst application. Do you have the latest version of that? You can get it from their website.
Jun 01, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
I can not get x1300 card to work on intel 865glc mb.
I have seen this before.have you tried turning the onboard video off in the bios menu?also in the bios there might be a setting something like primary graphics adapter.make sure it is set to agp.if your board uses shared memory for the video you may need to turn off all shared memory.also removing the batterie and power cord for a min will reset your machine back to factory settings,this might get it working ,or if something goes wrong and you lose all video(do this).also make sure your video card has all the power cords plugged into it.
Also your video card could just be a bad card.test it in another machine if you can
Mar 01, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
White screen with radeon x1300 pro agp 256m
Hi porkchop_66_ , if you uninstalled factory graphics drivers, chances are you uninstalled the motherboards built in graphics card driver. Since you haven't provided your motherboard model & manufactures name I can't be 100% your weren't using an onboard graphics card. So I'll cover both.
If you added the X1300 AGP card, (Not replacing an older AGP card), you'll need to enter the motherboards bios menu & set the bios to boot to the AGP slot. If you replaced an older AGP card, its possible you have the monitor plugged into the wrong VGA out-put on the Radeon. There are two ports. One DVI & one VGA. Try each & check for display. Lastly, the Radeon X1300 card you have
runs in an AGP port that supports 1.5volts. Check your, motherboard manual. Check if your motherboard supports AGP cards of 1.5v.
If all this does not make sense, post back with your motherboards model number & the manufacture name & I'll be able to help further. Post here.
Good luck porkchop_66_!
Thank you for using fixya.
Mike
Jan 14, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
HIS Radeon X1300 Misdetected
do the BIOS update !
in the advanced BIOS features there should be a onboard GPU tab, put it on disabled or on initiate AGP/PCI first (depends on the BIOS), so to be sure that the onboard card is disabled !
Connect the display to the HIS ...video card , and at least on bootup there should be info displayed on the screen . If not than : - try to reinsert the video card (bad connection ) (also check if its a card that needs external power source ( i doubt it))
- check if the video card is compatible with the motherboard (should be in the user manual, or on the producers site ... )
- check on another comp. if the card is good ....
hope it helps u ... if not, give more details ....
Jan 21, 2008 | HIS X1300 RADEON X1300 PCIe 512MB (128 MB)...
ATI RADEON X1300 PRO, (256 MB) AGP Graphic Card Logo
310 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
