Dropped in the toilet, can it dry out and work again? (needless to say it does not work now)
SOURCE: Plantronics Voyager Pro bluetooth headset
You want to turn off the power to your headset and turn off your phone.
Remove for 30 seconds the battery from the phone and reconnect. Then
follow the pairing instructions found on pages 4-5 in this link
for the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
SOURCE: my plantronics voyager pro will not charge turn on
I have seen on some Plantronics Bluetooth headsets that you can perform a
system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair
button. The headphones will show a solid red or blue light when they
have been successfully reset.
SOURCE: I cannot connect my Plantronics
Once you make your iPhone discoverable, then put the Plantronics
Voyager Pro headset into pairing mode by holding the power button until
the headset flashes red and blue. Here is the link below for the
Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
SOURCE: how do i put a plantronics voyager pro into
The instructions on the link below will walk you through the pairing process:
