Question about Gaggia Baby Espresso Machine
Problem with steam
I am having problems getting steam from my gaggia baby class, im not even sure i am doing it right....please help before i throw it!!!!!!!!!!!!
    Problem Solver:
  • 5 Answers
I'll take the machine if you are throwing it away:) You have a blown fuse. There are 2 fuses inside the mahine. Uplug the mahine, Pull the top of and locate both fuses. Connect a wire going from one end to the other of the fuse. This will temporarily short circuit the fuse. Now plug the machine in, and test it out. If it works, than that is obviously the bad fuse. If not, try the exact same procedure on the other fuse. My thermal fuse went out and it only set me back $1.98 to fix. Good Luck!
Posted on Jan 14, 2009
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Baby gaggia steamer doesn't work
Does the machine brew hot coffee? If yes, then remove the parnello and clean the holes at the end of the steam wand. If that does not solve problem, then it is blocked where valve is connected to boiler, Try descaling machine. If no then the thermostat on the boiler has tripped and needs to be reset.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Steam not working
i dont know your location, but you can check this sites mentioned above:
www.oemmeci.it
www.nuovaricambi.it
or you can check in car parts shops at your location, you should look at parts> sealings for brake pipes.... you request the sealing from rubber named VITON or SILICON.
Feb 28, 2009 | Gaggia Classic Espresso Machine
Operating instructions
Look on the website of www.coffeeitalia.co.uk They have manuals for most machines to download, Or try gaggia website.
Nov 29, 2008 | Gaggia Baby Espresso Machine
Baby Gaggia White Color
If you take of the top then you can see the boiler, on the top of the boiler you will see thermostat in the middle on one you will see a little pin, press down the pin to reset.
Jun 29, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Baby Espresso Machine Logo
910 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
