Question about Sony XM-1002HX Car Audio Amplifier
Broken output signal
Can not get a clear sound. Sound is broken up, have tried switching between high, low and no filter. Have tested speaker from source, both speaker & CD player are good.
Thanks
Stu
  • Anonymous Jan 06, 2009
    Speaker wires and connections are all good. Have removed cover on amp, looks as though the output tansistors have been over-heated, the soldering of the middle leg on 2, has melted.
    Stu
  • stu_mel Jan 06, 2009
    Have solved the problem. tansistors still okay, just required resoldering.
    Stu
    Problem Solver:
  • 3 Answers
Sounds like you have some loose speaker wires somewhere, or touching wires. check to make sure ALL wire connections are solid, and sealed with tape or a connecter. if any wire is touching any metal on the car or another wire it will cause interference
Posted on Jan 06, 2009
How do I work out why there is no sound at all from one of my speakers. I have switched them and it is definitely the speaker
After confirming speaker is not getting the audio, need to work toward the audio output. Your next stop will be the audio output from the power amplifier (if there is one), or if the audio is coming out of the car radio. If audio is at the source output (or amp out), you have a broken wire between the source and the speaker. Bypass this wire to test.
Jan 27, 2015 | Cars & Trucks
Radio has no sound
First check whether the connector for the speaker wires is firmly plugged in behind the radio. Try unplugging and replugging to make sure. (Note: the connector may be attached to the radio or it may be on the end of a short length of wire.)
If the speakers are firmly plugged in and you still don't get sound, the next step is to test the speakers. Do this by unplugging the wires behind the radio, then run a meter across one pair (for one speaker) to make sure you don't have an open circuit (broken connection). Alternatively, feed audio from the speaker outputs on a boombox or other stereo to that pair of wires. If you don't get sound or if the meter says there's an open circuit or direct short, either the speakers are bad or there's a broken wire between the radio and the speakers. Most bad connections happen at one end of a wire or the other, so look at the connectors at the radio and at the speakers.
Finally, if the speakers do check out, you'll have to test the car radio itself. Run a pair of wires for one speaker from the radio's outputs to an external speaker (any working speaker will do). If there's no sound, your radio is broken.
Of course, the easy way to do this is take it to a place that installs car radios. They can check it out quite easily and make recommendations. Don't take it to a Chevy dealer. They'll charge you a fortune, and if the radio is bad, they'll sell a refurbished unit for more than you'd pay for a high-end Kenwood or Pioneer.
Oct 08, 2014 | 1998 Chevrolet Cavalier
My subwoofer will not wake up, regardless of whether I flip the switch from Auto to On or not. Suggestions?
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
If you've got power then that's a good thing. It could be something simple as a broken solder joint or bulging capacitor.
Aug 05, 2014 | Harman Kardon HKTS 14 System
Output distortion from bass amp
The amp is clipping the signal. This could be from the input being too high. The impedance being too low or the finals are damaged.
Dec 11, 2017 | Behringer BXL1800 180W 2-Ch Bass Amp 12In...
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
1999 DODGE DAKOTA HEADLIGHTS NOT WORKING , i HAVE CHECKED ALL THE FUSES AND REPLACED THE HEADLAMPS, STILL NOTHING, WHAT ELSE CAN IT BE?
Sounds like either a headlight switch or a broken ground. Did you lose both the hi and low beams? Do your parking lights work? The headlight switch outputs to the hi/low selector on the column. If both hi and low beams are out I would check output voltage from the switch. Sounds ike that make be your issue. Good luck and let me know if I can assist further.
Nov 15, 2010 | 1999 Dodge Dakota
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
No sound from a Philips model 60P8341...
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Jul 03, 2008 | Philips 60P8341 60" Rear Projection...
Car Audio & Video Logo
67 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
