Question about Toshiba 57HDX82 57" Rear Projection HDTV
Color is off can't line up the 3 color lines
Able to line up blue red and green in all but 3 spots blue and red line up but need to move green line to meet them and can't don't know how to move green
  • 10,594 Answers
Hi, Green is basic color in rear projection TV and you need to move red and blue over to green. Sequence of convergence adjustemnt is like ...Green, Red and Blue
Posted on Jan 05, 2009
  • Toshiba Master
  • 19,396 Answers
If you are using auto focus the green must go along the with the other two automatically.
If you are using service alignment procedure and does not line up, then there is probably a fault on the convergence board, usually a convergence IC that is defective.
  • Ginko
    Ginko Jan 05, 2009
    Yeah go to cmpalmer website, good advice.
    Good luck and all the best.
  • Ginko
    Ginko Jan 05, 2009
    If red and blue do not converge with green on autofocus, there is need for a convergence setup procedure. If red and blue do not converge with green during convergence setup procedure, then you may have a fault.
  • Toshiba Master
  • 13,433 Answers
Hey it sounds like a convergence IC problem and the IC*S would need to be replaced to repair the problem.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
please look at the before and after pictures on the bottom of the page to confirm if this is the issue you are facing.
Vertical lines on my plasma tv
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | Samsung Televison & Video
How do i fix black spots on my LG plasma tv. model 50pj350ub
Jan 08, 2017 | LG 50PJ350 50 HDTVReady Plasma TV
My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Jan 07, 2017 | Toshiba Televison & Video
I have an LG model 55LH40 purchased in 2010,Screen has a greyish smoke colored vertical streaks in it, very noticeable on a white background. Any ideas what may be wrong?
Jan 07, 2017 | LG 55LH40 55 in. LCD HDTV
The color on my TV is all pink. I have tried a hard reset but it didn't help.
Your TV has lost a GREEN color from a basic color palette (Red-Green-Blue). It is often caused by:
- damaged LCD cable (which connects the display with a signal board inside the TV),
- damaged video signal cable (ex. SCART, HDMI, VGA),
- damaged video processor (on the signal board).
I can't give you a more accurate answer, because I don't know what is your TV mark and model and, in what situations you have the problem.
Jan 19, 2015 | Televison & Video
Cant find the location of the dc fuse panel for 2010 hy line premier rv
Have you looked in the engine compartment? Under the refer, sometimes behind a false door in a cabinet.
Oct 19, 2014 | Televison & Video
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Televison & Video
Plasma tv sony need help
hi could be the cable connecting from the inverter to the lcd.
May 19, 2013 | Televison & Video
Tcl tv line through screen
maybe vertical ic be came hot and make some lige unconnected in board have to go to tv tichnican
May 18, 2013 | Televison & Video
Toshiba 57HDX82 57" Rear Projection HDTV Logo
150 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
