Question about Dryers
My GE Profile dryer #DPSR473GW0WW is screaching! It is worth fixing? Is it hard to fix?
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
  • 54 Answers
SOURCE: Need Help
Have you tried unplugging it for 3 min? That will reset the computer. If that don't work you might need a new touch screen \ computer
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Jul 30, 2009
garing
  • 998 Answers
SOURCE: Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Posted on Aug 11, 2009
  • 4 Answers
SOURCE: front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Posted on Nov 23, 2009
My GE profile harmony dryer blows cold air on any setting do I need to replace heating element?
Yup...heating element (usually there are two) is done. Likely the first one was done long ago and the second has finally died.
Dec 03, 2013 | GE Profile Harmony DPGT750EC Electric...
The dryer does not heat up the timer isn't working, the dryer will stay on until manually turned off
Hi, Your timer is bad...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 15, 2010 | GE Profile DPSR473EW Dryer
What part is needed to fix the dryer when there is
if it's a gas dryer probably an ignitor. electric dryer, the element.
May 22, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
May 14, 2010 | GE Profile Harmony DPGT750EC Electric...
Our ge profile electric dryer has recently started to make a screaching sound while it is running
Your problem sounds like drum rollers is in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 13, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Need Help
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Squeaky Dryer
the support rollers are drying out plz post your email i will send you the how to get to them and fix this you have to be handy though
Mar 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
