Question about Vacuums
Sewing machine won't pick up bobbin thread
When I am threading my sewing machine, the needle will not pick up the bobbin thread as usual. I have made certain that everything was correctly threaded, clean, I changed the needle, and have tried it with different bobbins and thread spools.
  • Anonymous Mar 12, 2014
    bobbin thread isn't picked up
  • Anonymous Mar 13, 2014
    Needle will not pick up bobbin thead
Open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
  • Jerry Huerta Jun 18, 2013
    The bobbin is the only thing turning
Can not catching the bobbin tread at the bottom
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 18, 2016 | Singer Model 347 Instruction...
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website:". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Thread gets under needle while sewing. needle then cuts thread. is this a bobbin tension problem? thanks!
Hi. My guess would be no. Sounds more like an upper or needle thread tension problem than a lower or bobbin thread tension problem. Your trouble could also be the thread take-up lever was missed when threading the machine. Trace the thread path to make sure the threading is correct. Is this an embroidery machine? If not, were you trying make a darning stitch? Perhaps with the foot raised? Keep in mind that raising the foot loosens the upper thread tension.
Sep 09, 2011 | Vacuums
Thread jamming on Viking 5710 sewing machine
Check to see if the bobbin is wound in the right direction. Check to see if the bobbin case area is free of lint and debris. Has it been a while since you last used it? Check to make sure it is threaded correctly by following the arrows if this is a newer sewing machine. Last. Thread direction through the needle can be wrong. Vikings usually thread front to back. If you recently changed a broken needle, it could have been replaced in the wrong direction. make sure the flat edge of the needle is fed into the corrosponding flat area inside the needle case. I hope this helps you!
Sep 05, 2011 | Vacuums
I have inherited a White Sewing machine, model 4050. I have an older model White, so am familiar with the basics. Followed directions carefully regarding top threading and loading the bobbin - but I...
indicates that the needle /hook timing is off
check this by putting the needle in the fully down position and then as you start to get it back up the hook should be at or just near the eye of the needle
Jul 19, 2017 | Vacuums
In my Singer Sewing Machine model 1014 the Needle Won't Pick Up Bobbin Thread. Could you please help. Thanks
There could be several things causing this.
First, be sure the bobbin is in the bobbin case correctly. There is usually a line diagram showing the correct placement or you can check the owner's manual.
Second, make sure your needle is inserted correctly. If it is not completely set in the housing, this can prevent the bobbin thread from being caught by the hook. The groove in the needle should be ffacing toward you to assure that the thread interacts with the hook.
Third, be certain the upper threading is correct...passing through all thread guides and correctly through tension and take up lever.
Finally, make sure the bobbin case is free of lint. The machine brush that came with the machine will clean this area well.
I hope one of these suggestions helps you solve your problem. If so, please come back to Fixya and rate my advice!
Jul 24, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
It dose not sew, and when it dose the bobbin tangles up and lets out too much thread
The bobbin goes into the holder in what would appear to be the wrong direction ie, the thread doubles back. If this is correct, the bobbin tension might be too low, there is a screw on the bobbin holder to set the tension.
Jan 24, 2011 | Singer Vacuums
Vacuums Logo
293 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
