Question about APC Back-UPS® XS 900 (BX900R) UPS System
Apc bx900 wont turn on
I plug it in, and press power button. Nothing happens including no lights. Only the 4 protector plugs show power
  • 37 Answers
SOURCE: APC Smart UPS 3000VA - Dead UPS
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
Posted on Mar 28, 2009
  • 5 Answers
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
Posted on May 12, 2009
skipsinclair
  • 152 Answers
SOURCE: APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
Posted on May 27, 2009
jvpacoin
  • 91 Answers
SOURCE: apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Posted on Aug 14, 2009
  • 732 Answers
SOURCE: APC BP650S - will not turn on
validata, First things first!!! take the zero volts UPS battery out to your car and jumper charge it with your jumper cables! charge it for 5 to 10 minutes and disconnect it and then measure it to see what the voltage is!!! Is it 9v or 0v or 11.3v or what??? You must verify that you have a battery that can accept charging current and also be able to source at least 1.5amps and not have a significant drop in voltage when battery has a load across it! Use two 25ohm 25w wire wound resistors in parallel for a load of just under 1 amp. if terminal voltage falls off more than 1 volt, try charging for i hour and repeat load test. 12fixlouie
Posted on Nov 15, 2009
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
There is a hideous whistle coming out of the unit! We can't stop it by removing all devices that are plugged into it or by pushing the round button on the front. The overload light is illuminated but...
This sounds like the gel cell battery in the unit is dead. The battery life usually is about 2-3 years and then it needs to be replaced. The BX900 UPS uses qty 2 of the 12volt 7amp hour gel cell batteries. You should be able to get them from your local battery wholesale business or computer store, even Radio Shack. The replacement batteries should run about $40-50 To replace them just open the cover and unplug the old batteries and plug in the new set.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 07, 2010 | APC Back-UPS XS900 (BX900) UPS System
My APC BE500U keeps resetting
It certainly indictes a problem with the APC unit a replacement bettry may or may not solve the problem. Do you really need one as you have an anti surge protector?
Sep 18, 2009 | APC 500VA BE500U Back-UPS ES...
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Acer Aspire 7004 wmsi Will not start.
When you press the power button does anything happen? such as lights or LED's illuminate?
You could try the following -
1. Make sure there is nothing plugged into the computer (USB devices or memory cards etc etc).
2. Remove the power cable & the battery
3. Press the power button for 30 seconds
4. Insert the charger but not the battery and try and start it up.
If that doesnt work check the USB ports for damage and the port where the charger is plugged in aswell.
If they are damaged or it still wont start it will probably need repairing.
Jan 18, 2009 | Aspire (ATX-AS500W-BL) (atxas500wbl)...
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
APC Back-UPS® XS 900 (BX900R) UPS System Logo
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
