Question about Toshiba Satellite A135-S2276 Notebook
Laptop turns on but screen shows nothing??
I have a Toshiba Equium A100-027. For the past few days i have had to use Safe Mode as it keeps turning off every 5 minutes but when i use safe mode it doesnt. Today i tried turning it on. It switched on but when it came to the screen where i log in the screen was blank. Could someone please help me fix this? I really need your help as i urgently need to use my laptop! =(
  • rona_a Jan 05, 2009
    How do i do that?
    How do i do that ??
  • 44 Answers
Set to another resolution mode like 600x800, its likely that it may be set to a mode your screen cannot display.
Posted on Jan 05, 2009
Hi, I have a toshiba equium A110-233, a little elderly I know ! All was working fine until I turned it on a couple of days ago and now only get the initial toshiba screen then nothing, not even the cursor...
Hi shirley_ann1,
This problem that you have with your PC is a NO BOOT issue. After getting the startup Toshiba logo it's not booting up to your Windows. This could be a hardware or software problem depending on the result of the diagnostics that I'll be walking you through below, but definitely this issue can still be fixed.
Here's how:
1. If this is a software issue you can determine it by booting up on safe mode. To go to safe mode:
  • Shutdown the computer then turn it back on
  • The moment you turn on you PC keep on tapping F8 button until Safe Mode menu shows.
  • Then select Safe Mode, press enter.
If you'll be able to boot up on Windows using Safe Mode then you just have to reload your operating system. You will use the recovery disc that goes with your machine when you purchase it.
2. If it's a hardware issue you will not be able to boot up even on Safe Mode or even go to BIOS when you keep on tapping F2 during startup. This means your harddrive is corrupted or defetive. It needs to be reimaged or replaced.
Hope this will help you resolve your concern.
Thank you for using Fixya.
Feb 21, 2011 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
I just brought a new laptop ( toshiba, satellite) turned it on for the first time set few settings quickly then closed the lid for a few moments when i opened it up again it was off so i turned it back on...
Upon turning it on keep pressing the F8 key to obtain the repair screen
Choose start windows in the safe mode with the COMMAND PROMPT
When the screen shows C:/ type in chkdsk /f /r
Then restart the computer
If the windows still won't start take the unit back for exchange or have the BOOTMGR installed
Jul 17, 2010 | Toshiba Satellite A60 Notebook
My toshiba equium laptop keeps randomly turning itself off - this could be after 5 mins or after 60 mins, but could be fine for a couple of days!!!
your symptoms point towards a intermittent cooling problem...You might need to remove your cpu cooling fan, clean it up, and re install it, with new thermal paste. Make sure all fans in your computer are working as they should, including the power supply fan too.
Nov 20, 2009 | Toshiba Equium 100 PC Desktop
When I update my display driver from standard VGA
hi, you can first boot it in safe mode,, then go the display settings,, from control panel,, then change the things,, where you can find,, double display.. and single
Sep 27, 2009 | Toshiba Equium 7100S PC Desktop
I need to reboot my toshiba equium l10-300 laptop with no cd
Try starting in safe mode. Hold down oth the control and F8 kays and press power. Do not release Contro & F8 until it starts to beep. Then it shoud start in safe mode. If the computer will not start in safe mode you have a hardware problem. If it starts in safe mode, you have a Windows problem that re-installing Windows will solve that (to a point). Without the Original CD and install code, you have two options. Buy a new OS or.......pirate it. I do not recommend the last.
May 28, 2009 | Toshiba Satellite L10 Notebook
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Toshiba equium l20-197 booting
Chances are that it is a driver problem, try booting in safe mode by pressing f8 during the initial bot up process and selecting safe mode, with or without networking, if your systems goes in to windows then you have a drive issue, as safe mode loads with only the basic drivers needed to run windows, hope that helps
Dec 14, 2008 | Toshiba Equium 100 PC Desktop
Toshiba Equium L20 Laptop crashed
is it running in safe mode just press the F8 key and start in safe mode
and restore the system .
Oct 19, 2008 | Toshiba Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
