Question about Breville BES820 Espresso Machine
Breville coffee maker has broken plastic tube connector
Steam line plastic connector snapped off
SOURCE: breville 800esxl won't extract coffee or steam milk.
is your machine new or is this a new problem? If you have had the machine for a while there is a possibility that your double wall filter is clog between the walls which would prevent the water from going through (this happens when your grind is too fine). If however the water does not go through when you do not have a filter in the basket than you have a diferent problem.
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Posted on Mar 18, 2009
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Posted on Dec 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: My Breville Keurig coffee maker turns itself off
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Posted on Jun 22, 2010
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
My Breville BES820XL isn't steaming the milk. Instead it drips a little and then the steam comes out the shower head. Any idea what is causing this and how to fix it?
Maybe the end of the steam wand is clogged. Use the tool that comes with the maker to clean it. Do this with the coffee maker turned off.
May 06, 2015 | Breville BES820XL Espresso Machine
The plastic connector at the solenoid valve broke causing machine to leak water.
The connection needs an o-ring and a washer in order to be water tight. I hope you still have the old ones from the plastic version.
The pressure seal is at the tubing/o-ring/inside-wall of the connector, not the tube-end/bottom. The washer's job is to compress the o-ring a little so it presses against the connector's inside wall and the tubing's outside wall. There's a ferrule inside the tubing to give the tubing crushing-resistance.
A tiny daub of food-safe grease around the o-ring (say, vaseline) will help ensure water-tightness and help with reassembly.
O-ring:
http://www.forumappliances.com/breville-o-ring-for-bes-830xl/
Washer:
http://www.forumappliances.com/breville-silicone-washer-for-800esxl-special-order/
As far as the clip being loose, it shouldn't fall out easily. The looseness is due to the missing parts.
May 03, 2015 | Breville BES830XL
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
No steam no hot water
Do you have enough water in the tank? Is the filter secured in the tank?
Move the steam dial from standby to steam and wait about 20-30 seconds, should steam if it doesn't most likely faulty.
Jun 14, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Why does the pump make a knocking sound when using the steamer
The steam is hitting water somewhere in the tubing....this is not a problem... it's just the natural reaction that happens when very hot steam hits cooler water...
heatman101
Apr 17, 2011 | Breville ESP8XL Espresso Machine
No rubber fitting on steam arm
The rubber fitting does 2 things. It splits the steam and it keeps the end from bumping too hard. You don't need it but make sure you clean the steam tube well.
Jan 25, 2009 | Breville ESP8XL Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Mobile connector for steam tube...
not sure if you got the part. I called Saeco USA and they sent me the little swivel joint which supposedly is a strong plastic component. check with them
May 21, 2008 | Starbucks Saeco Italia Digital Barista...
Breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Feb 24, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville BES820 Espresso Machine Logo
37 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
