Question about HP LaserJet Office Equipment & Supplies
Scanner Error 22
HP LaserJet M1213 MFP show error on screen 'Scanner Error 22' please provide solution.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Error 22 can occur when a correct positioning of the LED does not occur "CIS scanner engine" or its displacement is not correct.
In principle you can start disarming the glass flatbed with a torx wrench 10 clean and lubricate the gear guide and gears and wheels that are on the edge of the strip of LEDs. reassemble and test.
good luck
Richard de Argentina
Posted on Dec 03, 2014
Scanner Error 22
Posted on Apr 03, 2014
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
  • 1382 Answers
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
Posted on May 18, 2010
seeker5211
  • 1089 Answers
SOURCE: scanner error 6 in hp laserjet m1120 mfp
Cable may not be connected correctly, try reconnecting the scanner cable. Or the scanning software is corrupted. Try uninstalling and reinstalling the software. Did your scanner ever work?
Posted on May 27, 2010
  • 8 Answers
SOURCE: ERROR SCANNER 22 EN IMPRESORA
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Posted on Dec 02, 2010
Scanner error 22 M1213nf mfp
why it is showing scanner error 22 message
Feb 23, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
The error message on the printer screen says: scanner error 22
The error is scanner error check the scanner in moving or not if not then check the scanner cable is broken or dust on scanner rod clean oil it properly
Dec 28, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Lazer jet M1120 MFP scanner error 22
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
Nov 03, 2010 | HP LaserJet M1120 MFP All-In-One Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
566 people viewed this question
Seeker5211
Seeker5211
