Question about Philips 9P5040C TV
Tv picture when turning on the tv, the picture only stays on for a minute and then goes black.
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
  • 252 Answers
SOURCE: takes 5 minutes for tv to stay on
the IF transformer of the video section is in trouble (change value) try to adjust using a plastic or wood stick look for AFT .
Posted on Oct 01, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
  • 148 Answers
SOURCE: After turning on tv screen stays up for 1 minute
Hi there, first off, place a fan as close to the back of the tv as you can, this could prolong the use of your tv by cooling down the powerboard inside, The reason why your tv is doing this is becouse the caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not) then please rate, thankl you!05f6799.jpg
Posted on Feb 05, 2010
  • 19 Answers
SOURCE: Picture great then goes black
has to do with the main board like the other guy said go to way cheap and its that one cuz was told to me by the manufacturer you call tv repair man they give you all this **** it can be the power supply or the main board bring it so we can tell you just to get the money for checking it out go to this site get it but be real careful with the screen you can do it your self i did mines aint no science.
Posted on Apr 17, 2010
  • 4234 Answers
SOURCE: Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Posted on May 04, 2010
0 characters
1 Points
Tv problem
Check its horizontal output section circuit for any loose solder terminals. Resolder all suspected solder terminals by applying little more fresh solder. Replace the horizontal output transistor. If this transistor have some leak, it will overheat within minutes will shut down the picture.
May 26, 2012 | RCA 27F530T 27" TV
I have an old tv, a small one, that works OK when you first turn it on, then after 5 or ten minutes the picture goes black. But, the picture will come on briefly if you lightly tap on the top of the TV (or...
There's a solder connection, probably on the CRT board that s going bad. It's an easy fix but if you're not trained to be working on CRT tvs I suggest finding someone who is. Good luck
Mar 05, 2010 | Zenith Standard (CRT) Televisions
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
Jan 24, 2010 | Philips Magnavox 27MT5405 TV
I have an older admiral tv. The picture goes in and out.
check the terminals of the might have a loose connection..try to resolder...otherwise you need to check both horizontal and vertical output..
Jun 14, 2009 | Standard (CRT) Televisions
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Oct 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Philips 9P5040C TV Logo
22 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
