Question about HP Officejet 5610 All-In-One InkJet Printer
I am getting a close the access door error message-door is closed
The access door is closed, have turned off turned on opened closed and taken out the ink cartriges & reinstalled.
    Genius:
  • 2,120 Answers
Check the door in the rear of the machine.
Posted on Jan 05, 2009
Error code 3806
From Kodak support:
Open the printer access door.
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer.
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Close the printer access door.
Remove and install the printhead two times.
Wait until the printer is ready to use.
Jun 07, 2012 | Kodak   ESP5250 Es Printer
I cannot clear the "Door
Hi
When you open the print cartridge access door there is a black toggle switch that needs to be in the depressed position to let the unit know the door is closed. If the cartridge door is not completely closed, the error message displays.
1. Open, and then close the cartridge door of the product. Make sure that the door rests securely against the body of the product.
NOTE: To see how to close the cartridge door of your specific model, see the cartridge section of your product's User Guide.
2. Check the product control panel to see if the error message still displays.
If the issue persists, see the next step.
Check the cartridge door for obstructions
1.Inspect the door and the area around it to make sure that no obstructions prevent the door from closing completely.
NOTE: Bits of paper, packing materials, and tape might prevent the door from closing completely.
2. Remove any obstructions.
3. Check the product control panel to see if the error message still displays.
If the problem still persists you need to reset the product...
1.Press the Power button to turn on the product.
2.Disconnect the USB cable from the back of the product.
3.Disconnect the power cord from the electrical outlet.
4.Disconnect the power cord from the product.
5.Wait 30 seconds.
6.Reconnect the power cord to the electrical outlet.
7.Reconnect the power cord to the product.
8.Press the Power button to turn on the product.
9.Reconnect the USB cable to the product.
10.Check the product control panel to see if the error message still displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | HP OfficeJet 7130 All-In-One Printer
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Error # 3802
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Nov 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Printer shows error code 3802 printer will not print
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Says printerehead mising noy installed properly or has come loose. I have taken caridges out , printer head out reinstalled and still say there is a problem
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
  6. Close the printer access door.
If issue continues, contact kodak for printhead replacement.
Nov 17, 2009 | Kodak ESP 5 Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet 5610 All-In-One InkJet Printer Logo
217 people viewed this question
Ben Johnson
