Question about Xerox Phaser 240 Thermal Printer
I have TVSE 240 printer that have parreal port for PC conection, but in my New PC and Laptop this port is not available, how can i use this printer with my new PC and Laptop that have USB port only
  • avibcb
    avibcb Nov 11, 2012
    actually my printer is a dot matrix printer and it has only parallel port for PC connections. all most all the PCs and Laptops do not have any port for parallel bus. all of these have only USB port. so i am not able to connect my PC /Laptop to my printer. i was a suggestion how to connect a parallel port printer to usb port laptops/PCs
  • 7,627 Answers
With most printers there is a software download for your printer. Download and install the software should walk you through the process. That said, plug in the USB into your New PC and the software should find a driver, i don't know your OS, and it SHOULD work. You may not get the Full fuctions of the printer until you install the Full software for the printer. If this is your printer the software will be found here, in case you do not have it:http://www.support.xerox.com/support/phaser-240/downloads/enus.html?operatingSystem=win7x64 I do not see that it is wireless? Just connect to the New PC via a USB port in the rear of the new PC. Use Device and Printers on start menu to ADD a Printer. When you have added the printer, right click and choose Sharing, Share this Printer. Set up a Home network on the New PC that has the printer attached. Re-Boot. On your laptop set up to the Home network that you just created on the NewPC with the printer. Reboot the laptop, you will get a network message like Welcome to "your: network. Go to the laptops printer section in start menu and Add a Printer, it will pop up if configured correctly, some changes may be made in Network and Sharing. Now you can print through your network "wirelessly". if you need assistance respond to this post.
Posted on Nov 09, 2012
Inky
  • 691 Answers
SOURCE: usb printer problem "port in use please wait"
Can you advise which operating system you are using? Assuming 32bit windows: Unplug the printer from the USB and try deleting the printer from the printers folder. Then download the latest driver from the Canon web site. Once you have you have it, in the control panel go to SYSTEM and into HARDWARE tab and then DEVICE MANAGER. Look under UNIVESAL SERIAL BUS CONTROLLERS and check that there are NO yellow symbols. If there are yellow symbols you need to remove the offending item from the list (making a note of it's description) and then reboot your machine. When it comes back up it should advise that new hardware has been found and go through the process of installing the drivers. You can now go the manufacturers web site and download the USB controller driver for your device. If the file is a zip extract it to a folder on your PC. When it asks if it can go online to find a suitable driver, let it do so and you can also specify a location for it look (where you extracted the download above) Once it finds the driver required and has finished installing it, reboot your system and then install the printer driver you just downloaded. Hopefully this will get you back on the go. If you have a windows 64 bit system I'm afraid you are on your own. 64 bit drivers that work are very hard to come by. Let us know if this is any use to you, if not we may more to offer.
Posted on Sep 16, 2007
SOURCE: VISTA drivers
HP had the most bad printers for vista and xp.
If you buy a HP, you buy problems!
For this problem i'm also searching, lexmark is a good merk, neither is HP!
Posted on May 23, 2008
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
  • 18 Answers
SOURCE: canon bjc 50 printer
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Posted on Aug 20, 2009
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Posted on Apr 30, 2010
I was using TVSE Nova 130 printer on my pc parallel port with win xp pro os and it was working properly. Now I want to connect the printer to my laptop which has only a usb port. So I purchased a bafo...
go to device and printer. Locate your printer . right click the printer and select printer properties. click the port tab then change the printer port from LPT to usb port.
Jan 22, 2014 | Computers & Internet
Tvs msp 255 driver needed
go to
http://drivertube.net/?p=24
click download to TVS MSP 240 All Driver (163.3 KB). Good Luck!!!
neo
Mar 02, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I WANT TVS 250MSP DOTMATRICES PRINTER DRIVER
i have this driver just mail me on pankaj.lcet@gmail.com . I will send it to u for free for sure.
Feb 24, 2009 | Office Equipment & Supplies
Tvse nova 130 printer drivers needed --cannot print from vista
TYPE IN ADDRESS BAR
MANUFATURES NAME, MAKE, MOLDEL, DRIVERS
ROD
Feb 09, 2009 | Office Equipment & Supplies
Wifi
Yes you should be able to with a USB cable. Most later models have either an Ethernet or USB cable port available on the printer.
Jan 03, 2009 | Office Equipment & Supplies
INSTALLATION PROBLEM
howcan i get driver of tvs msp 240 classic free
Dec 01, 2008 | Epson LQ-2180 Dot Matrix Printer
Mp240 Canon printer not responding.
just go to the printer folder right click the printer and then choose properties then click the ports tab and find a usb port. check it and click apply. then it should work. if not then i cant help you sorry. i had the same problem and the sollution was the port.
Nov 01, 2008 | Computers & Internet
Sipix printer
msp tvse 345 printer is not work
Mar 15, 2008 | SiPix Pocket Printer Thermal
Xerox Phaser 240 Thermal Printer Logo
312 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
