Have a 4 wire ac/heat system, installed new thermostat, cannot reconnect them as the leads were not labeled and the old thermostat was broken
  • dwkcool May 11, 2010
    what color are the 4 wires and what king of ac/heat is it
    Problem Solver:
  • 10 Answers
Give me the the model number and Mfg of your equipment along with the color codes at the unit, not the thermostat wire at the thermostat, and I can assit. Contact me directly.
Richard (Rick) Drennan
Global HVAC Distributors
Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
Posted on Jan 05, 2009
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
Havc thermostats
I will assume you did not write down what color wire you took of each letter on old thermostat? Sometimes color of wire doesn't matter as some installers will use whatever color. If you noted where each wire was on old thermostat, just put same color wire to same letter on new one. Under normal situation. y is for compressor (cool) G, is for fan (on AC) , RC is 24 volts from transformer for AC side, RH is 24 volt transformer from heat/furnace, and W is for other wire from furnace, is furnace is only 2 wire system. Was there any wire connected to A on old thermostat?
Apr 11, 2012 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
I'm replacing my old thermostat with a honeywell
usually you should have 4 or 5 wires....if you have AC then this wire should be Y if not was it connected at all before?...Heating requires only R&W
Oct 24, 2009 | Honeywell Electronic Programmable...
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Thermostat problem
Buy some more thermostat cable with the same number of conductors inside it that you need. Twist the wires in the wall to the conductors on the new cable you just bought. Wrap the connections with electrical tape and pull the new cable with the old cable, starting at the furnace. You will then have all brand new conductors to fit to your new thermostat.
Jan 12, 2009 | Honeywell Electronic Programmable...
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
