Question about Whirlpool Duet GHW9150P Front Load Washer
It shows LF on screen - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
See other post.
Posted on Nov 09, 2012
Model #W10284544A is showing LF. What does it mean?
I bet the machine is trying to tell you that the lint filter is clogged.
May 29, 2018 | Whirlpool Washing Machines
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
Apr 29, 2016 | Maytag Washing Machines
What does the LF code mean?
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
  • Is water supply connected and turned on?
  • Are hose screens plugged?
  • Is water entering the tub? If so check pressure hose connection to machine/motor control.
  • See TEST #2 in manual
Jun 20, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer is not finishing cycle shows the code LF
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Aug 17, 2011 | Kenmore Washing Machines
Letter LF appear where the time should read. The washer just beeps and does not finish the load
This is a long fill (LF) check the inlet hoses for the screens being clogged...if it takes longer than 10 minutes to fill ..it cuts off and shows LF ..check that either water valve is not turned off or almost turned off...also, alot of people just use cold...make sure the selector is set for cold/cold if using this cycle...another possible fault is the mixing valve is bad/or going bad..Either way consentrate on this and you'll find your solution
Bruce Denton
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
The washer is showing a code of LF what does this mean
LF Long Fill
If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Whirlpool Duet GHW9150P Front Load Washer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
