Question about LaCie (300728U) 250 GB Hard Drive
Wierd click noise
When I plug up my external, it starts making this weird clicking noise, and it isn't mounted. I don't see it under my computer or anything. Is there anyway i can recover anything on here or anything?
    Novelist:
  • 198 Answers
Hello man, Unfortunatelly not, by conventional means. This problem occurs most often due to excesive shocks received by the hard drive but it can also occur in another situation most often forgotten by people or didn't taken in consideration. A hard disk isn't voided as many people think, it's actually presurised, and it works by creating a air flow current wich lifts the reading heads over the physical disks at about 1 mm. The reading heads doesn't actually touch the drive. If however a power spike occurs, the main motors spin speed may be altered, therefore the air current may drop in strenght and the heads may come down to actually touch the disks. This results in very bad circular scratches over the disk, somethimes making it unusable. Most hard disks have protections that prevent this but they somethimes don't work well. In order to recover the data in this case, the hard disk must be dissasembled and the disks must be placed in another specially made universal controll drive in a controlled atmoshpere environment. This sounds expensive, and it is, most times you woun't find someone (or a service center) with the devices and knoledge to do this. If the motor controller (an electronic component on the main board of the drive) fails, also this results in the above problems. However like I've stated in the beginning this is a very hard to fix problem and most shurelly not in a DIY fashion. Sorry for not being able to assist you further in this problem
Posted on May 24, 2007
My 2004 t&c 3.8 is making a weird sound like a
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
Computer does not recognize external hard drive, western dig 320 g. It has been making clicking noises before it started this problem.
Clicking noises are not an issue, as the hard drive uses voice coil technology, which clicks. Plug into another USB drive.
Jan 22, 2011 | Western Digital My Book Essential Edition...
I have a 320gb beyond micro external hard drive. it has been working fine up to yesterday. when i turned it on it started making a wierd noise, sort of like a humming noise that has a kind of pattern to...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 24, 2010 | Beyond Micro Computers & Internet
Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
Not making a clicking noise, but actually playing a really wierd sound
The tones in repetition sound could be a defective harddrive. I've had that happen once on an internal harddrive...
May 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Weird noises, not recognized by laptop
This is a common problem with hard drives. Most hard drives (whether external or internal) that produces a "weird clicking noises" indicates a mechanical problem. Often this is the head arm trying to move from its position but failing to do so. What you are hearing as "weird clicking noises" are when it slaps back to its park position or when trying to move into correct position.
Should this be the case, am afraid that the HD is a goner. The normal course of action is to replace. If the data inside are mission critical, your only course of action is to avail of those data recovery by firm specializing in such but they are rather expensive.
Trying to use "data recovery software" might prove to be futile since as earlier stated, the problem is mechanical in nature.
You can of course still give it a try.
Should you feel adventurous, would be willing to experiment and gamble, pls post back as I may have not a permanent solution but a "down & dirty" trick of making it run long enough hopefully to get some of your data back. Again, this is a "hit or miss" and should only be considered if all else fails and you really want to get your files back.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | LaCie d2 Extreme with Triple Interface...
LaCie (300728U) 250 GB Hard Drive Logo
211 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
