Question about Kicker Car Audio & Video
ZX 1000.1 amp stays in protection mode
My kicker zx 1000.1 amp goes into protect mode as soon as you put power and ground to it nothing else hooked up
  • 1 more comment
  • flmobilemech
    flmobilemech Nov 09, 2012
    it does the same thing with the speakers hooked up
  • Rob getz Nov 09, 2012
    There is a internal problem with it then, The older ones were not verry relible, There was allways (Problems) With them, Screwing up within a couple of months.
  • thunderalley
    thunderalley Apr 30, 2014
    amp fried
    Master:
  • 689 Answers
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Posted on Nov 09, 2012
SOURCE: Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Posted on Apr 21, 2008
  • 1126 Answers
SOURCE: kicker amp goes into protection mode as soon as i
Have you tried powering on without speakers connected? Have you tried powering on with no input? If either senerio causes the amp to NOT go into protection mode, then there is most likely a short in wiring. Use a multi meter to isolate.
Posted on Jun 12, 2009
SOURCE: KICKER AMP
sounds like a bad ground or power.
Posted on Jul 12, 2008
fixerdlt1
  • 18 Answers
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Posted on Jul 22, 2009
  • 7 Answers
SOURCE: Is my amp or wiring bad? volfenhag zx-8400, 2000watts amp
Sounds strange,
Put a voltmeter on your car, to see if the voltage is stable when the engine is running.
if it is unstable, turn your car off immediately, to avoid damaging other electrical components.
If the voltage does not stay between 12.8 - 14,5volts (engine running) then the Rectifier is shot on your alternator.
Is your Amp screwed to the metal of the car? B'cos it shouldn't be.
if that doesnt help, try another RE-wire (you may have missed something) after refreshing your memory with an AMP wiring diagram.
Or just take it out & get it tested,
if its out of warrenty open & inspect the circuits for burns, a shop will charge just to look at it.
Posted on Sep 19, 2009
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Kiccker ZX200.4 the protection l,ight stays on
disconnect all the speakers from it.. turn it off and then on again, if the protection light is still on your amp has gone out and id take it to a pro to get it fixed. you might be better off getting a new one though.
Nov 05, 2009 | Kicker ZX200.4 Multi-Channel Amp - 140W ZX...
Kicker zx 1000.1 green light flickers and no sound
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Any one kno anything about these kicker zx 2500.1
yea u should as long everything is hooked up correctly ur sound will be great u dont need all that. all of those is because his pushing alot of power and a giant amp its most for that big amp.
so yea hook it up and it should sound good
Jun 27, 2009 | Car Audio & Video
KICKER AMP
Jul 12, 2008 | Car Audio & Video
Kicker ZX 750.1
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
711 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
