Question about LG LS-L1210CL Mini Split Air Conditioner
My split air con unit is leaking water from the unit in house
  • dwkcool May 11, 2010
    check the drain line for the unit
    Scholar:
  • 67 Answers
The things that you can check yourself are
is the indoor unit level?
Are the filters clean?
The area the water is draining to free of obstruction?
Is the drain actually draining?
----Get a cup of water and pour it over the indoor coil (please make sure the power is off first please) If the water does drain then it is prolly a bigger problem.
Prolly your unit is short of gas and need a refrigeration tech out to check. That it isnt ice-ing up but you would notice the performance drop.
Hope this helps
Posted on Jan 08, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Air conditional water drip
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Apr 20, 2014 | Sanyo Split System Air Conditioner
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
My outside toshiba split system is leaking a lot of water
If the unit is on heat mode, the outside unit is the "cold" end... Sometimes if the ambient air temperature is very cold ( Under 5 degrees C), the outdoor unit can start to ice up. If it ices up too much, the air con will automatically go on to a defrost cycle where the outdoor unit will heat up and melt the ice. Water is then drained out the bottom.. its the opposite of what happens in the summer when the indoor unit has water running out of the drain hose. Especially on humid days..
Jul 16, 2011 | Fujitsu Heating & Cooling
My Panasonic Air Con (CS-C12GKH) is leaking water. This happens every few months and each time I have to get a technician to come. Is there a way to permanently resolve this problem?
The water is leaking due to a blocked drain (because of accumulation of mud). If you are able to clean it on your own, you don't have to call the technician. When you remove the houseing of the indoor unit, you can see the water collection tray at the bottom of the unit - thats what you have to clean.
Feb 14, 2011 | Panasonic Room Air Conditioner CWXC104HU
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
LG LS-L1210CL Mini Split Air Conditioner Logo
2,333 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
